How do you change the browser node name in a drawing?
GosponZ
Message 1 of 15
GosponZ
Is it possible to make iLogic rule to do this:
In dwg Place part and in Browser to see part name without extra typing. Not Sheet 1 sheet 2 etc.
That would be huge help.
Thank you
Accepted solutions (3)
Replies (14)
Message 2 of 15
jdkriek
Here you go:
If (ThisDrawing.ModelDocument Is Nothing) Then Return
	modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
	ActiveSheet.Sheet.Name = iProperties.Value(modelName, "Project", "Part Number")
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 3 of 15
GosponZ
Thanks for  such fast reply but here is one error could you take look please.
Thank you
Message 4 of 15
jdkriek
I'm not getting that error in 2011-2013
Is there anything else in the iLogic rule? Can you post it?
To make sure it's copied correctly you can also copy and paste from this .txt file attached.
Jonathan D. Kriek
Message 5 of 15
GosponZ
Thanks a lot now is working perfect
Message 6 of 15
jdkriek
Glad it works for you 😉
Jonathan D. Kriek
Message 7 of 15
GosponZ
Jonathan,
when i try first time it work perfect. Now i'm trying and every time in new sheet giving me same name
Thank you
Message 8 of 15
jdkriek
Ah multiple sheets with diffrent parts? Try this.
oDoc = ThisDoc.Document
oSheets = oDoc.Sheets
	For Each oSheet In oSheets
		oSheet.activate
		oView = oSheet.DrawingViews.Item(1)
		modelName = oView.ReferencedDocumentDescriptor.ReferencedDocument
		oProp = modelName.PropertySets.Item("Design Tracking Properties")
		ActiveSheet.Sheet.Name = oProp.Item("Part Number").Value
	Next
oSheets(1).activate
Jonathan D. Kriek
Message 9 of 15
GosponZ
I copy paste straight from web and that is not good idea. I place code into word and then i copy paste into rule and is working like charm. Thanks a lot
Message 10 of 15
jdkriek
You're quite welcome 😉
And yes, paste directly into a .txt file before pasting into iLogic.
Jonathan D. Kriek
Message 11 of 15
Sorry to bring up an old thread but this code isn't working in Inventor 2014. Any ideas?
Message 12 of 15
GosponZ
Man i'm still on 2012. Is there anybody to try with 2014
Message 13 of 15
GosponZ
In 2014 code is working perfect. Not single problem.
Message 14 of 15
thats genius work. thanks.
Message 15 of 15
aronmatheus
Hi@jdkriek I'm trying to think of a ruler same you did not lose the link with the parameter when using ilogic, I put a video to show what I wanna do.
