How do we create part or drawing or assembly programatically?
Message 1 of 10
Hi Experts,
                 We have a requirement to create standart parts ,drawing and assembly as part of our functionality . Can you please let me know how can we achieve this?
note: These part will be created blank with no geometry,sketches and other details.
Thanks and Regards
Rajesh
Replies (9)
Message 2 of 10
Hi ,
Using VBA macro in Inventor you can create a new part like this,
Sub newDoc()
 Dim oPart As PartDocument
Set oPart = ThisApplication.Documents.Add(kPartDocumentObject, "C:\\Users\Public\\Documents\\Autodesk\\Inventor 2011\\Templates\\English\\Standard (in).ipt", True)
End Sub
Another way using VB.Net console Application.....
1.Here im trying to connect a running inventor or starting new inventor application
2.Then creating a new part document.
Module Module1
Public inventorApp As Inventor.Application
Public inventordoc As Inventor.Document
Public invPDoc As Inventor.PartDocument
Sub Main()
' Enable error handling.
Try
' Try to connect to a running instance of Inventor.
inventorApp = GetObject(, "Inventor.Application")
Catch ex As Exception
Try
' Try to open Inventor.
inventorApp = CreateObject("Inventor.Application")
inventorApp.Visible = True
Catch ex2 As Exception
' Unable to start Inventor.
MsgBox("Unable to connect to or start Inventor.")
Exit Sub
End Try
End Try
Threading.Thread.Sleep(5000)
inventordoc = inventorApp.Documents.Add(Inventor.DocumentTypeEnum.kPartDocumentObject, "C:\\Users\Public\\Documents\\Autodesk\\Inventor 2011\\Templates\\English\\Sheet Metal (in).ipt", True)
End Sub
End Module
Same way you can create empty drawing & Assembly file.Hope it helps..
Message 3 of 10
Hi Expert,
              Thanks for the quick reply. I have couple of questions, can we implement the same using C#? Can we create a blank drawing and associate to part later?
@Anonymous for a asking the question: I have to create a part or drawing or assembly. and then check in the vault programattically.
Regards
Rajesh
Message 4 of 10
In c# also you can do this as below.But i dont know about checking or comparing files in vault.
using System;
using System.Collections.Generic;
using System.Linq;
using System.IO ;
using System.Text;
using Inventor;
using System.Runtime.InteropServices;
using System.Diagnostics ;
using System.Threading;
namespace InventorCSharp
class Program
static void Main(string[] args)
Application inventorApp = null;
Document inventordoc = null;
// Enable error handling.
try {
// Try to connect to a running instance of Inventor.
inventorApp = (Application)Marshal.GetActiveObject("Inventor.Application");
catch (Exception ex)
// Connecting to a running instance failed so try to start Inventor.
try {
inventorApp = (Application)Activator.CreateInstance (Type.GetTypeFromProgID("Inventor.Application"),true );
inventorApp.Visible = true;
catch (Exception ex2)
// Unable to start Inventor.
Console.WriteLine ("Unable to connect to or start Inventor.");
return;
System.Threading.Thread.Sleep(5000);
inventordoc = inventorApp.Documents.Add(Inventor.DocumentTypeEnum.kPartDocumentObject, "C:\\Users\\Public\\Documents\\Autodesk\\Inventor 2011\\Templates\\English\\Sheet Metal (in).ipt", true);
Message 5 of 10
Work great, thanks for the code and explanation.Since am very new to this it helps me lot to understand.Great work and thanks once again.
Message 6 of 10
Hai, Since am very new to Autodesk i need a help. I want create a drawing in autodesk inventor though VB. So for i have open the auotdesk application using VB.net code. If any one have idea to create new drawing code using VB .Net in autodesk please let me know. Thanks
Message 7 of 10
dgreatice
Hi all,
Already search from this forum using search engine with subject "Create Drawing"?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 8 of 10
tonythm
You can try this:
Sub newDoc()
Dim oAssembly As AssemblyDocument
Dim oDrawing As DrawingDocument
Set oPart = ThisApplication.Documents.Add(kPartDocumentObject, "C:\\Users\Public\\Documents\\Autodesk\\Inventor 2019\\Templates\\TMStandard.ipt", True)
Set oAssembly = ThisApplication.Documents.Add(kAssemblyDocumentObject, "C:\\Users\Public\\Documents\\Autodesk\\Inventor 2019\\Templates\\TMStandard.iam", True)
Set oDrawing = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\\Users\Public\\Documents\\Autodesk\\Inventor 2019\\Templates\\TMStandard.dwg", True)
End Sub
Message 9 of 10
please explain the difference
Message 10 of 10
JelteDeJong
did you see this blog post?
https://adndevblog.typepad.com/manufacturing/2012/06/creating-a-drawing-from-scratch-with-the-invent...
Jelte de Jong
Blog: hjalte.nl - github.com
