how do i catch the AppFileSaveCopyAsCmd event.
I need to be able to filter out if a user uses the save copy as button in inventor.
the application event OnSaveDocument does not help because this is fired on all save events.
the userinput events OnActiveCommand does not help because it does not recognize the command AppFileSaveCopyAsCmd.
please help.
Regards kent boettger
forget this issue,
found the solution.
Private Sub x_FileUiEvents_OnFileSaveAsDialog(ByRef FileTypes() As String, SaveCopyAs As Boolean, ParentHWND As Integer, ByRef FileName As String, Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles x_FileUiEvents.OnFileSaveAsDialog
If SaveCopyAs = True Then
MsgBox("SaveCopyAs was selected")
Else
MsgBox("SaveAs was selected")
End If
End Sub
