How do I add a workpoint at an xyz coordinate
JBEDsol
Message 1 of 10
JBEDsol
 Public Sub AddWorkPlanebyOriginOffset(strWPName As String, strOffsetPln As String, dblDist As Double)
        Dim pntOffset As WorkPoint
        If appApp.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            Dim ptdocCurrent As Inventor.PartDocument
            ptdocCurrent = appApp.ActiveDocument
            Dim ptcdCurrent As PartComponentDefinition
            ptcdCurrent = ptdocCurrent.ComponentDefinition
            If strOffsetPln = "XY Plane" Then
                pntOffset = ptcdCurrent.WorkPoints
            ElseIf strOffsetPln = "YZ Plane" Then
            Else
            ptcdCurrent.WorkPlanes.AddByPlaneAndOffset(ptcdCurrent.WorkPlanes("XY Plane"),)
        Else
            Dim assydocCurrent As Inventor.AssemblyDocument
            assydocCurrent = appApp.ActiveDocument
            Dim assycdCurrent As AssemblyComponentDefinition
            assycdCurrent = assydocCurrent.ComponentDefinition
        Dim wpPlane As Inventor.WorkPlane
        wpPlane = cdCurrent.
    End Sub
This is where I'm at with trying to make a routine to add a workplane offset by some user parameters.  When I look at the workplane it needs an object so I set about creating a point at and xyz location.  I can't seem to get it to work, can't figure out how to add via xyz.
Replies (9)
Message 2 of 10
Michael.Navara
I don't uderstand your code and what are you try to do. But This code creates workpoint at specified coordinates
Dim x = 1
Dim y = 2
Dim z = 3
Dim activePart As PartDocument = ThisDoc.Document
Dim oPoint As Point = ThisApplication.TransientGeometry.CreatePoint(x, y, z)
Dim oworkPoint As WorkPoint = activePart.ComponentDefinition.WorkPoints.AddFixed(oPoint)
and this code creates work plane offseted from YZ work plane
Dim oWorkPlanes As WorkPlanes = ThisDoc.Document.ComponentDefinition.WorkPlanes
Dim oPlane = oWorkPlanes(1) 'YZ WorkPlane
Dim oOffset = 1 ' 1 cm
oWorkPlanes.AddByPlaneAndOffset(oPlane, oOffset)
Message 3 of 10
JBEDsol
That is much easier, thank you.
Message 4 of 10
chris
@Michael.Navara concerning your above code, is there a way for the grounded work point to update if the rule is ran again where the X.Y,Z numbers are changed? Currently it just creates another work point, but can it be created so that it just updates the original work point created, and can the rule contain a line of code to allow the work point to be named within the code.
I ask because I have to create a few dozen work points, but I also need them to be able to update and change values
Message 5 of 10
Curtis_Waguespack
Hi @chris ,
Here is a quick example of redefining an existing workpoint location.
I hope this helps.
Curtis
Dim x = 1
Dim y = 2
Dim z = 3
Dim oworkPoint As WorkPoint = Nothing
Dim wpName = "Best WorkPoint Ever"
Try
	oworkPoint = activePart.ComponentDefinition.WorkPoints.Item(wpName)
	z = InputBox("Enter Z", "iLogic", oworkPoint.Point.Z)
Catch
	oworkPoint = Nothing
End Try
If 	oworkPoint Is Nothing Then
	oworkPoint = activePart.ComponentDefinition.WorkPoints.AddFixed(oPoint)
	oworkPoint.Name = wpName
oworkPoint.SetFixed(oPoint)
Message 6 of 10
chris
@Curtis_Waguespack When I set up and run your rule, it has a dialog box asking for an "Enter Z", what is that for?
If I edit the iLogi rule and manually change the X,y,z, numbers, why is it asking for "Enter Z"?
Message 7 of 10
chris
@Curtis_Waguespack Nevermind, I figured it out
Message 8 of 10
chris
@Curtis_Waguespack the only problem I have run into is that when I try and type in something like this;
-(67*12)+6.375    for   67'-6-3/8"
for the dialog box for X,Y, or Z it gives me this error.
Message 9 of 10
chris
@Curtis_Waguespack  it would be nice if Inventor would just allow XYZ in parameters for the location of a work point. I like how simple your above code is, but those numbers are not stored anywhere, nor can the user see what the numbers are in a list, not to mention it doesn't like equations for inputs.
Message 10 of 10
_dscholtes_
You could add a function to your code that evaluates your equations and uses the end results as input for creating workpoints to create this behaviour. The  'Units of Measure' object is quite powerfull in evaluating expressions and converting units.
@chris wrote:
...but those numbers are not stored anywhere...
You can retrieve those numbers from the workpoint itself:
oWorkPoint.Point.X, oWorkPoint.Point.Y and oWorkPoint.Point.Z
