How do I active Inventor with Ilogic ?
Darkforce_the_ilogic_guy
Advisor Advisor
I need to get it my ilogic code  to active the current aktice veiw port . Like it will do I I click on it with the mouse
anyway I can to that ?
A.Acheson
What object would you like to activate and in what document? Can you share an image of what you need?
Regards
Alan
I need to be able to use the send key command to aktive a shortcut using ilogic
A.Acheson
So you need to use the command manager to activate the command. Which command is it? And what object do you need to select? Drawing View, Browser Node etc? Using Send Keys can only work in limited commands and sometimes timing does not work.
Regards
Alan
no i do not need  command manager.. Because the command does not exists in  command manager. (Shared Views).
That I need is it need the viewport to be active ... before sending the sendkeys
A.Acheson
Ok so with the shared view help file dialog you are wanting to copy a link to clipboard correct?
"When you create a shared view, a pop-up window provides the link to the shared view in Autodesk Viewer. This makes it easy for you to send the link to your collaborators. Your collaborators do not need an Autodesk product. Collaborators can review and post comments directly in Autodesk Viewer"
Can you copy the link using the keyboard only either by pressing tab to enter the dialogue and tab/arrow button to navigate the dialog or do you need to use the mouse to copy the link? Can you make a video of the process you are following?
I was able to piece together your information from this other forum post you have.  It might be better to use just one forum post request so all information is in one place and change the title to better describe your request.
Example Forum Post Title:
"Copy link from Shared View dialog box to clipboard"
Regards
Alan
