How can i get unit of area in Ilogic
18154093
Message 1 of 9
18154093
Hi guys
I don't know how to get unit of area (SF)  in Ilogic
this my code
Dim C as Double
C = iProperties.Area
iProperties
.Value("Custom", "AREA") = Round(C, 2)
Everybody has idea this problem
Thanks all
Replies (8)
Message 2 of 9
A.Acheson
Hi @18154093
You will need to construct the string  containing the area value and unit string.
Dim C as Double
iProperties
.Value("Custom", "AREA") = Round(C, 2) &" SF"
 Just in case your using sheet metal parts and you need to get the area of flat pattern here is the link
Regards
Alan
Message 3 of 9
18154093
i tried and this problem
Message 4 of 9
A.Acheson
Can you show the parts list before using the group method? I am not getting the roll up error here.
Regards
Alan
Message 5 of 9
18154093
I use string "SF", because i don't know how to get unit of area in ilogic
Something's wrong ?
Message 6 of 9
A.Acheson
ft^2 would be the unit string for sq feet. I am not sure if custom units are accepted in the parts list tools. The units are not existing as standard. Maybe some more forum searching will yield a result for you.
Regards
Alan
Message 7 of 9
Maxim-CADman77
Judging by search by "Area" within UnitsTypeEnum help-page you can get Area in Acres and CircularMils only (which is pretty strange).
Please vote for Inventor-Idea Text Search within Option Names
Message 8 of 9
18154093
this is not acceptable, because in the type board does not have unit of area
Message 9 of 9
A.Acheson
How about changing the unit of measurement in the document of the part to Area instead of qty. This is commonly done for sheet material. This way the qty will be added up. 2 ft^2 instead of qty 2 @1 ft^2. See tutorial on this method here
Regards
Alan
