How can I create these "Parameters" with iLogic instead of using the Parameters window?
chris
Advisor Advisor
Message 1 of 22
chris
I'm trying to see if there is an easier way to create "User Defined Parameters" instead of using the Parameters window in Inventor. I need to be able to create each parameter with an "initial" value, but then obviously be able to change that value later. The below example shows a numeric in, numeric angle, unitless, text and true/false.
I'd like to know if I can also set up the multi-value list when creating these in iLoigc, as well as add the notes, and also if it is a key or to be exported?
Is this possible and can someone show an example?
I have a project where I have to enter a ton of user defined parameters and I want to group them, and inevitably you always forget a parameter when trying to group them and of course we can't we order in the parameters window... ;-(
Replies (21)
Message 21 of 22
Curtis_Waguespack
Hi @chris, see this example.
Sub Main
	oObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	Dim ParamList As New ArrayList
	'           Name  | Value | Unit | Comment
	'_____________Add Parameter Below This Line _________________________
	'Parameter Group 1
	oObjectCollection.Clear
	ParamList.Clear
	ParamList.Add("User_Parameter_001|9.125|in|Notes")
	ParamList.Add("User_Parameter_002|8|deg|Notes")
	ParamList.Add("User_Parameter_003|9|ul|Notes")
	'send strings to sub routine
	For Each ParamString In ParamList : CreateParams(ParamString) : Next
	Add_Parameter_Group("Param Group 1")
	'Parameter Group 2
	ParamList.Clear
	ParamList.Add("User_Parameter_004|9.125|in|Notes")
	ParamList.Add("User_Parameter_005|8|deg|Notes")
	ParamList.Add("User_Parameter_006|9|ul|Notes")
	Add_Parameter_Group("Param Group 2")
	iLogicVb.UpdateWhenDone = True
End Sub
'variables shared among subs
Dim oObjectCollection As ObjectCollection
Sub CreateParams(ParamString As String)
	'split each string using the | as the split character
	StringArray = Split(ParamString, "|")
	ArrayCount = UBound(StringArray)
	If ArrayCount < 3 Then
		MsgBox(ParamString & vbLf & "Only " & ArrayCount & " ' | ' seperator chrs in string" & vbLf & "Expected 3, you might need to add one to the end", , "ilogic")
		Exit Sub
	ParameterName = StringArray(0) 'first item in array
	ParameterValue = StringArray(1) 'second item in array
	ParameterUnit = StringArray(2) 'etc
	ParameterComment = StringArray(3) 'etc
	'set up conversion factors
	Dim DocumentUnitsOfMeasure As UnitsOfMeasure = ThisDoc.Document.UnitsOfMeasure
	Cnvt_cm_to_in = DocumentUnitsOfMeasure.ConvertUnits(1, UnitsTypeEnum.kInchLengthUnits, UnitsTypeEnum.kCentimeterLengthUnits) 'cm to inch (2.54)
	Cnvt_Rad_to_Deg = DocumentUnitsOfMeasure.ConvertUnits(1, UnitsTypeEnum.kDegreeAngleUnits, UnitsTypeEnum.kRadianAngleUnits) 'rad to deg (57.2958)
	Dim UserParams As UserParameters = ThisDoc.Document.ComponentDefinition.Parameters.UserParameters
	Dim MultiList = New ArrayList
	MultiList.Clear
	If ParameterValue = "True" Then 'convert ParameterValue to boolean
		ParameterValue = True
	ElseIf ParameterValue = "Null" Then 'convert Null to empty string
		ParameterValue = ""
	ElseIf IsNumeric(ParameterValue) Then	'convert ParameterValue string to number
		ParameterValue = CDblAny(ParameterValue)
		If ParameterUnit = "in" Then ParameterValue = ParameterValue * Cnvt_cm_to_in
		If ParameterUnit = "deg" Then ParameterValue = ParameterValue * Cnvt_Rad_to_Deg
	ElseIf ParameterValue.Contains(",") Then 'process list of values for multivalue
		'split each string using comma as the split character
		StringArray2 = Split(ParameterValue, ",")
		'add strings to arraylist
		For Each ListItem In StringArray2 : MultiList.Add(Trim(ListItem)) : Next
		'set multivalue param value to the first item in the list
		ParameterValue = MultiList.Item(0)
	Dim param As Inventor.Parameter
	Try'try to get parameter
		param = UserParams.Item(ParameterName)
	Catch'The parameter doesn't exist so add it
		param = UserParams.AddByValue(ParameterName, ParameterValue, ParameterUnit)
		'set value and comment for existing params
		param.Value = ParameterValue
		param.Comment = ParameterComment
		'if multivalue then set list
		If MultiList.Count > 0 Then MultiValue.List(ParameterName) = MultiList
	End Try
	oObjectCollection.Add(param)
End Sub
Sub Add_Parameter_Group(ParameterGroupName As String)
	Dim oDoc As Document = ThisDoc.Document
	Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
	Dim oCustomParamGroup As CustomParameterGroup
	Dim ParameterGroup As CustomParameterGroup
	Try
		'Delete CustomParameterGroups if one exist in order to add new parameters
		oCompDef.Parameters.CustomParameterGroups("ID_" & ParameterGroupName).Delete
	Catch
	End Try
	'create group
	ParameterGroup = oCompDef.Parameters.CustomParameterGroups.Add(ParameterGroupName, "ID_" & ParameterGroupName)
	'add parameters to group
	For Each oParam In oObjectCollection
		ParameterGroup.Add(oParam)
	Next
End Sub
results should look like this
Message 22 of 22
chris
@Curtis_Waguespack This works great! I was really hoping that when I tried to link a part or assembly that has "Parameter Groups" that they'd show up in the "linked Parameter" list, that way I could easily link a group without having to pick and choose which user defined parameters from what could be a very long list... that's a major bummer 😞
