Change viewcube orientation of parts from Assembly
xenocatalyst
xenocatalyst
Hi All,
I am trying to develop this code but have come across a hurdle.
The goal is to
access the referenced parts in an assembly,
filter using part name (P is used for this, filename format is: part-P001.ipt),
get the solidbody orientation,
set view to match the solidbody,
apply the changes to the camera/view,
set current view as front for the part file.
I can get this to work if i use the code to open each part, set the view then save and close.
I would prefer it if I didn't need to open each file.
The code below seems to work for all but set current view to front.
Any help would be welcome, Thanks.
Roy
Doc As AssemblyDocument = ThisApplication.ActiveDocument
For Each refDoc As Document In oDoc.AllReferencedDocuments
	' Check if the document is a part (we only want to work with parts)
	If refDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		Select Left(Right(refDoc.DisplayName, 8), 1)
			Case "P"
				' Process the part document
				Dim partDoc As PartDocument = refDoc
				' Get the component definition of the part
				Dim compDef As PartComponentDefinition = partDoc.ComponentDefinition ' Ensure the part has a solid body
				Dim solidBody As SurfaceBody = compDef.SurfaceBodies.Item(1)
				Dim omrbBox As OrientedBox = solidBody.OrientedMinimumRangeBox
				' Get the length of the OrientedBox along each direction
				Dim xDim As Double = omrbBox.DirectionOne.Length * 10 ' mm
				Dim yDim As Double = omrbBox.DirectionTwo.Length * 10 ' mm
				Dim zDim As Double = omrbBox.DirectionThree.Length * 10 ' mm
				' View Section
				' Get the directions and their lengths
				Dim dirX As Vector = omrbBox.DirectionOne
				Dim dirY As Vector = omrbBox.DirectionTwo
				Dim dirZ As Vector = omrbBox.DirectionThree
				' Create an array of directions with their corresponding lengths
				Dim vectorData As (Vector, Double)() = {
				(dirX, xDim),
				(dirY, yDim),
				(dirZ, zDim)
				' Sort vectors by their lengths (shortest to longest)
				Dim sortedVectors = vectorData.OrderBy(Function(v) v.Item2).ToArray()
				' The shortest vector is the first in the sorted array
				Dim zVector As Vector = sortedVectors(0).Item1
				' The longest vector is the last in the sorted array
				Dim yVector As Vector = sortedVectors(1).Item1
				Dim oCam As Camera = ThisApplication.ActiveView.Camera
				Dim Eyeposition As Point = omrbBox.CornerPoint.Copy() : Eyeposition.TranslateBy(zVector)
				'                ' Set camera properties
				With oCam
					.Target = omrbBox.CornerPoint
					.Eye = Eyeposition
					.UpVector = yVector.AsUnitVector ' Ensure UpVector is normalized
				End With
				' Set this view as the "Front" view
				oCam.Fit
'				oCam.ApplyWithoutTransition
				oCam.Apply()
				Dim oView As View = ThisApplication.ActiveView
				oView.SetCurrentAsFront
'				oCam.Parent.SetCurrentAsFront
'				oCam.Parent.ResetFront 'resets the front orientation
		End Select
Next
xenocatalyst
After doing some in depth research i have come to the conclusion that it is not possible to set the front view without changing the active view.
