How can I break link reference component of sketch
tim11_manhhieu
tim11_manhhieu
I am trying to break link reference component of sketch show as image.
Did i do something wrong?
Option Explicit
Sub zzzzzzzzzzz()
Dim oPart As PartDocument
Set oPart = ThisApplication.ActiveDocument
Dim oPartDef As ComponentDefinition
Set oPartDef = oPart.ComponentDefinition
Dim oSketch As PlanarSketch
Set oSketch = oPart.ComponentDefinition.Sketches.item("Sketch29")
oSketch.ReferenceComponent.BreakLinkToFile
End Sub
WCrihfield
Have you tried PlanarSketch.BreakLink method?
Another alternative may be to iterate through every SketchEntity in the sketch, and set the SketchEntity.Reference property's value to False, since that is a ReadWrite property.  It says the only valid value we can set is False, since just specifying True does not specify what the entity would be getting referenced to, and can not reestablish any association.
Wesley Crihfield
(Not an Autodesk Employee)
tim11_manhhieu
It's still error.
I tried method oSketchEntity.Reference = False and it worked.
The purpose of my breaking link is to remove the projected entity.
Although reference21 is still left, the above method is still OK.
