Creating custom iProperties in all Parts of an assembly AND putting them together in one custom iProperty
stigler
stigler
Hi!
I have an iLogic snippet, that works perfect for creating the user defined iProperties in all the components (parts and sub assemblies) of an assembly BUT when I want to put these iProperties together into one (divided by a ";") I have a problem!
Here is my snippet:
''' Regel zum Anlegen der Stücklisten iProperties in allen Bauteilen einer Baugruppe
Dim doc As AssemblyDocument = ThisDoc.Document
For Each refDoc As Document In doc.AllReferencedDocuments
    Dim customPropertySet = refDoc.PropertySets.Item("Inventor User Defined Properties")
	'''Anlegen des iProperty "BEMERKUNG"
	Try
        Dim test = customPropertySet.Item("BEMERKUNG")
    Catch
        customPropertySet.Add("", "BEMERKUNG")
    End Try
	Try
        Dim test = customPropertySet.Item("BEMERKUNG_Z1")
    Catch
        customPropertySet.Add("", "BEMERKUNG_Z1")
    End Try
	Try
        Dim test = customPropertySet.Item("BEMERKUNG_Z2")
    Catch
        customPropertySet.Add("", "BEMERKUNG_Z2")
    End Try
	Try
        Dim test = customPropertySet.Item("BEMERKUNG_Z3")
    Catch
        customPropertySet.Add("", "BEMERKUNG_Z3")
    End Try
	Try
        Dim test = customPropertySet.Item("BEMERKUNG_Z4")
    Catch
        customPropertySet.Add("", "BEMERKUNG_Z4")
    End Try
 '''Rule to put these custom iProperties together into one called BEMERKUNG (devided by ";")
iProperties.Value("Custom", "BEMERKUNG") = iProperties.Value("Custom", "BEMERKUNG_Z1") & ";" & iProperties.Value("Custom", "BEMERKUNG_Z2") & ";" & iProperties.Value("Custom", "BEMERKUNG_Z3") &
";" & iProperties.Value("Custom", "BEMERKUNG_Z4")
Next
What is wrong with my rule for the connection of the single iProperties - Bemerkung_Z1, ...?
Thank You for Your help!
stigler
....other idea:
I tried to create an iLogic Rule just for connecting of these 4 parts of the iProperties "BEMERKUNG" into one (devided by a";") for ALL parts and subassemblies of an assembly - what is wrong?
LFCR = Chr(13) & Chr(10)
''' Definition von BEMERKUNG - das iPoperty für Bemerkung
PN01 = iProperties.Value("Custom", "BEMERKUNG")
PN02 = iProperties.Value("Custom", "BEMERKUNG")
iProperties.Value("Custom", "BEMERKUNG") = Replace(PN16, ";", LFCR)
Next
It seamed to be an easy rule - BUT I have troubles
Thank You for help!
daltonNYAW9
try putting ".ToString" after all the property values
and add an "_" when continuing on the next line
