how can i access these in vba
hi,
how can i access these # 1 or #2 in vba.
can someone help me with some code pls...
i dont want the names to be hardcoded but instead selected by the user....
i would really appreciate it...
thanks a lot!!
ekinsb
You've had several similar questions but I think there is some confusion about what you're trying to do.  Can you explain the full workflow you would like to support?  For example, are you expecting the user to select one of the nodes you specified and then run your program and you want to find what they selected?  Or will the user run your program and then it will ask them to select one of the objects?  Or does the program somehow know which node and do the selection?
Brian Ekins
Mod the Machine blog
