Holepattern And count holes
Jesper_S
Jesper_S
Hi.
Im trying to make a special holepattern using iFeature.
Going to use it to make ha holedisk for meat grinders.
I have created a set of three holes in a "Delta-Shape" and then i do a rect. pattern of that feature. The left hole of the "Delta-Shape" will "overlap" the right hole when i do the pattern. (Maybe not the best way to do this).
Is there a way to count the holes made in the part or count them in the drawing? Can have from 10 holes up to 200 or even more.
//Jesper
//Jesper
b.mccarthy
Hello.
I found this code in the forums, which may do what you want, the caveat being that it only runs on a sheet metal parts. It counts "Edge Loops" not actual "Holes", but it returns the correct values:
Dim oDoc As PartDocument = ThisDoc.Document
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
  Dim oCD As SheetMetalComponentDefinition = oDoc.ComponentDefinition
  If oCD.HasFlatPattern = False Then
	oCD.Unfold
	oCD.FlatPattern.ExitEdit
  End If
  Dim oFace As Face = oCD.FlatPattern.TopFace
  Dim i As Integer = oFace.EdgeLoops.Count-1
  MessageBox.Show("Number of Holes: " & i)
End If
I developed my part as you did (created the delta shaped holes and patterned) and converted to sheet metal.
My coding skills are poor at best, so I do not know how to modify it to count holes in a standard part.
HTH
