Hole Note [_showLeader] = true
How I can activate Hole Note [_showLeader] = true and what actually happen.
WCrihfield
That is a curious line item. Perhaps its just an internal reference, hence the [brackets] around it. I don't see any Methods or Properties of the HoleThreadNote Object that seem to have any control over or access to that value.  I looked at the Dimsneion Style & Leader Style too, but I'm not seeing an option to toggle the leaders visibility.  Perhaps someone from Autodesk can answer that one.
Wesley Crihfield
(Not an Autodesk Employee)
maxim.teleguz
Okay if you tell me how did you pull up that information I can help you then solve this.
Its basically with set do this.
JelteDeJong
This is a read-only property of the "HoleThreadNote" interface. Maybe it is useful information in some edge cases but it's not a documented property. Also, the fact that this property starts with a _ (underscore) is a hint that this should not be accessible. (For programmers it's common to use an underscore in front of variable names that should only be accessed from within a class. So for me it is strange that it is exposed at all)
Anyway, you cant set it.
Jelte de Jong
Blog: hjalte.nl - github.com
maxim.teleguz
a = selectedset
if a.holenote = true then
a.[_showleader] = true
End If
something like this. but this isnt real code just a quick interpretation
or
with selcted set
End with
