Hole Note - Changing Decimal Seperator on Thread Pitches
PafecDOGS
PafecDOGS
Hi - we are currently revamping our CAD drawing standards to the latest BS8888: 2013 standard, one of the main changes is that the decimal seperator is no longer a point, but is instead a comma. We've managed to change this easily in Inventor in most cases, but one place we cant seem to change is the Hole Note when it shows a thread pitch (see pic below). We can't seem to find a setting anywhere - anyone know where it is please? Using Inventor 2014.
salariua
The only way I got this going was to edit the thread.xls in design data folder.
I am having hard feelings about it, I don't know how that's going to affect Inventor; I am thinking ifeatures, iparts, content center items .. etc.
Did you changed your regional and language settings in control panel as well? or you don't want that as a general windows behavior?
Edit:
You need to edit "Custom Thread Designation" column.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
PafecDOGS
Thanks for that! Will have a look at editing the xls file, but there are already a few things in the latest BS spec Inventor does not easily support (such as spaces between groups of 3 digits e.g a dim of "4000" should be "4 000", a dim on "0.3125" should be "0.312 5").
No, we dont want our whole system to show this change! We'll just stick to Inventor/AutoCAD for now! 🙂
salariua
I hate doing this sort of changes. It can have bad impact on the whole functionality of Inventor. We haven't changed completely to BS standard, playing it safe for now.
Adrian S.
blog.ads-sol.com
