Hole Feature and shared Sketch. VB and C# disagree
mirkomaga
mirkomaga
I trying to get Sketch Definition from Hole Feature.
Considering that it is the same document:
VB:
Addin c#:
As you can well see: in the second image the sketch throw me an exception that is not there in the first one.
This is Model, anyone have the same problem?
Zach.Stauffer
Can you share VB and C# code?
jatindevaiya08
@mirkomaga
I have created C# code for the same and it's working fine for me. See attached images.
Here is the C# code. It's console Application code. And note that Inventor application as well as Part is open when you test it.
Inventor.Application inventorApplication = (Inventor.Application)System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application");
PartDocument partDocument = (PartDocument)inventorApplication.ActiveDocument;
PartComponentDefinition partComponentDefinition =partDocument.ComponentDefinition;
foreach (PartFeature partfeature in partComponentDefinition.Features)
  if (partfeature.Type == ObjectTypeEnum.kHoleFeatureObject)
    HoleFeature holeFeature = (HoleFeature)partfeature;
    Console.WriteLine(holeFeature.Sketch.Name);
Jatin Devaiya
Accept it as solution.
Jatin Devaiya
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
