Hole color rule
Hole color rule
robmit_arm
Hole color rule
robmit_arm
Im currently creating rule to color holes depend on hole type. Im not programmer so Im very happy with what I achieved so far. Code is mostly copy/paste from many different rules and adjusted for my needs. I need a little help.
1. These two holes are made as simple hole and clearance hole. According do API they are under one enum (kDrilledHole - 21505- Hole is drilled (no countersink or counterboring)). Is it possible to split them so I have two different colors, not one. I have not found any information.
2. These holes are made as three hole features. When you mirror them in one operation the color is taken after first selected hole. Is it possible to have proper color for each hole using one mirror operation? Of course I can mirror each hole separately to get proper color for each hole.
3. I want to make additional color for dowel pin hole. I modified clearance.xls file and added additional fastener type. I set up color as "oColor8". I need a code to recognize dowel pin hole. Hole 20 on the model (INV2023).
It should be something like this.
If kDrilledHole = 21505 and FastenerType = "dowel pin hole" then
oAsset = oColor8
robmit_arm
Will anyone help? Especially with 3rd point as 1 and 2 are not so important.
khnam
Did you find the solution for number 1?
There was no eunmer to distinguish between a simple hole and a clearance hole....
Andrii_Humeniuk
Hi @robmit_arm . I optimized your code and solved your 3 problems. I hope this is what you wanted. Solution to question 3 lines 54-58.
Sub main()
	'initial release
	'v0.9 / 2023-11-15
	Dim oInvApp As Inventor.Application = ThisApplication
	'part veryfication
	If oInvApp.ActiveDocumentType <> kPartDocumentObject Then
		MessageBox.Show("uruchomić z poziomu części", "UWAGA", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
		Exit Sub
	End If
	'part definition
	oPartDoc = oInvApp.ActiveDocument
	'component definition
	Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
	'drilled color definition / wiercona prosta, przejściowa
	Dim sColor(7) As String
	Dim oLanguage As String = oInvApp.LanguageName
	If oLanguage = "English" Then
		oAssetLib = oInvApp.AssetLibraries.Item("Autodesk Appearance Library")
		sColor = {"Orange", "Sky Blue Medium", "Dark Green", "Violet", "Magenta", "Anodized - Blue", "Orange-Red", "Cyan"}
	Else If oLanguage = "Polski" Then
		oAssetLib = oInvApp.AssetLibraries.Item("Biblioteka wyglądu renderingu Autodesk")
		sColor = {"Pomarańczowa", "Średniobłękitna", "Ciemnozielona", "Fioletowa", "Fioletowe", _
				"Anodowany — niebieski", "Pomarańczowo-czerwona", "Cyjan" }
	Else : Exit Sub
	End If
	Dim oTM As Transaction = oInvApp.TransactionManager.StartTransaction(oPartDoc, "ChangeColorHoles")
	Try
		Dim oLocalAsset1 As Asset = GetAssets(sColor(0))
		Dim oLocalAsset2 As Asset = GetAssets(sColor(1))
		Dim oLocalAsset3 As Asset = GetAssets(sColor(2))
		Dim oLocalAsset4 As Asset = GetAssets(sColor(3))
		Dim oLocalAsset5 As Asset = GetAssets(sColor(4))
		Dim oLocalAsset6 As Asset = GetAssets(sColor(5))
		Dim oLocalAsset7 As Asset = GetAssets(sColor(6))
		Dim oLocalAsset8 As Asset = GetAssets(sColor(7))
		For Each oHoleFeature As HoleFeature In oPartDef.Features.HoleFeatures
			If oHoleFeature.Tapped <> True Then
				Dim sInfoName As String = String.Empty
				Try : sInfoName = oHoleFeature.ClearanceInfo.FastenerType : Catch : End Try
				If sInfoName.Contains("kołek stalowy DIN 6325 / DIN 7979") Then
					oHoleFeature.Appearance = oPartDoc.Assets.Item(sColor(7)) ' dowel pin hole / otwór pod kołek
				Else
					Select Case oHoleFeature.HoleType
					Case 21505 :
						If oHoleFeature.IsClearanceHole Then
							oHoleFeature.Appearance = oPartDoc.Assets.Item(sColor(6)) ' drilled / wiercona prosta, przejściowa
						Else
							oHoleFeature.Appearance = oPartDoc.Assets.Item(sColor(0)) ' drilled / wiercona prosta, przejściowa
						End If
					Case 21506 : oHoleFeature.Appearance = oPartDoc.Assets.Item(sColor(1)) ' countersunk / pogłębienie stożkowe
					Case 21507 : oHoleFeature.Appearance = oPartDoc.Assets.Item(sColor(2)) ' counterbore / pogłębienie walcowe
					Case 21508 : oHoleFeature.Appearance = oPartDoc.Assets.Item(sColor(3)) ' spotfaced / pogłębienie czołowe
					End Select
				End If
			Else																' threated hole definition
				Dim ThreadInfo As Object = oHoleFeature.TapInfo()
				If Not ThreadInfo.Metric() Then
					Continue For
				End If
				If ThreadInfo.RightHanded() Then							' right hand
					If Left(ThreadInfo.ThreadDesignation(), 1) = "M" Then
						Dim nominal As String = ThreadInfo.NominalSize()
						Dim pitch As Double
						Dim pitch_st As String = ThreadInfo.ThreadDesignation()
						Dim Separators() As Char = {"x"c }
						Words = pitch_st.Split(Separators)
						pitch = Val(Words(1))
						Select Case Double.Parse(nominal)		' pitch size definition
						Case 2, 2.5, 3, 4, 5, 6, 8, 10, 12, 14, 16, 18, 20, 22, 24, 27, 30, 33
							Select Case pitch
							Case 0.4, 0.45, 0.5, 0.7, 0.8, 1, 1.25, 1.5, 1.75, 2 , 2.5 , 3, 3.5
								oHoleFeature.Appearance = oPartDoc.Assets.Item(sColor(4))
							Case Else
								oHoleFeature.Appearance = oPartDoc.Assets.Item(sColor(5))
							End Select
						End Select
					Else
					End If
				Else
				End If
			End If
		Next
		'pattern definition
		Dim oFeatures As PartFeatures = oPartDoc.ComponentDefinition.Features
		'rectangular pattern definition
		For Each RectPattern As RectangularPatternFeature In oFeatures.RectangularPatternFeatures
		    RectPattern.Appearance = RectPattern.Definition.ParentFeatures(1).Appearance
		Next
		'circular pattern definition
		For Each CirPattern As CircularPatternFeature In oFeatures.CircularPatternFeatures
		    CirPattern.Appearance = CirPattern.Definition.ParentFeatures(1).Appearance
		Next
		'mirror definition
		For Each MirrPattern As MirrorFeature In oFeatures.MirrorFeatures
			For i As Integer = 1 To MirrPattern.Faces.Count
				For Each oFeat As PartFeature In MirrPattern.Definition.ParentFeatures
					For j As Integer = 1 To oFeat.Faces.Count
						If oFeat.Faces(j).Evaluator.Area = MirrPattern.Faces(i).Evaluator.Area Then
							MirrPattern.Faces(i).Appearance = oFeat.Faces(j).Appearance
						End If
					Next j
				Next
			Next i
		Next
		'sketch driven Pattern
		For Each SketchPattern As SketchDrivenPatternFeature In oFeatures.SketchDrivenPatternFeatures
		    SketchPattern.Appearance = SketchPattern.Definition.ParentFeatures(1).Appearance
		Next
	Catch
		oTM.Abort()
		Exit Sub
	End Try
	oTM.End()
End Sub
'part definition
Dim oPartDoc As PartDocument
'asset library definition
Dim oAssetLib As AssetLibrary
Private Function GetAssets(ByVal sName As String) As Asset
	Try : oLocalAsset8 = oPartDoc.Assets(sName)
	Catch : oLocalAsset8 = oAssetLib.AppearanceAssets(sName).CopyTo(oPartDoc)
	End Try
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
robmit_arm
Wow. I knew my code is a mess and can be optimised. This is more than I expected. Thank you
Hello! Autodesk Inventor Professional 2016 - Simplified Chinese gives an error. Prompt "SketchDrivenPatternFeature" undefined type. Is there a solution? Thanks!
