Hide units in Part list
eladm
Message 1 of 16
eladm
Hi
I create a tube and pipes assembly in the drawing the part list is have mixed units :
Can I get a rule that delete/hide the units string ? it don't need to convert the value
regards
Replies (15)
Message 2 of 16
Andrii_Humeniuk
Hi @eladm . Not sure I understand exactly what you need. If you need to hide children rows (1.1, 1.2 ...) then use this code:
Dim oDDoc As DrawingDocument = TryCast(ThisDoc.Document, DrawingDocument)
If oDDoc Is Nothing Then Exit Sub
If oDDoc.ActiveSheet.PartsLists.Count = 0 Then Exit Sub
Dim oPList As PartsList = oDDoc.ActiveSheet.PartsLists(1)
For Each oRow As PartsListRow In oPList.PartsListRows
	Try : oRow.Expanded = False : Catch : End Try
Next
 If you need to hide rows that have children rows (1, 2, 3...), then use this code:
	If oRow.Expandable Then
		oRow.Visible = False
Next
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Message 3 of 16
eladm
Hi
You can see QTY column with units : mm / in
I want to hide them
1 - only hide them , don't change the value
2- convert them to m or mm (to be able to select ) and get the value without units
Message 4 of 16
Andrii_Humeniuk
Understand. The first part of the code hides all rows that have units (mm, in). The second part of the code changes the BaseUnits for all pipes to mm. The third part of unit hiding cannot be done in code because such methods are not available in the API. This can only be done at StyleMang. (see screenshot) .
	Try : oRow.Expanded = True: Catch : End Try
	If oRow(4).Value.Contains(".") Then : oRow.Visible = False
	Else : oRow.Visible = True
Next
Dim oADoc As AssemblyDocument = oPList.ReferencedDocumentDescriptor.ReferencedDocument
For Each oRefDoc As Document In oADoc.AllReferencedDocuments
	If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject _
		AndAlso oRefDoc.DocumentInterests.HasInterest("{4D39D5F1-0985-4783-AA5A-FC16C288418C}") _
		AndAlso Not oRefDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure Then
		Dim oPipeDoc As PartDocument = oRefDoc
		oPipeDoc.ComponentDefinition.BOMQuantity.BaseUnits = "mm"
Next
Message 5 of 16
eladm
Hi
The code didn't do anything (nothing happened after run rule, I tried with the whole code and half of it )
***What did you mean about 1st  , 2nd and 3rd parts ?
We can't use the style manager because it convert the unit  , It need to be with a rule
Message 6 of 16
Andrii_Humeniuk
Sorry in my case the QTY column was the fourth in your case it is the second column. You need to change line 7.
If oRow(2).Value.Contains(".") Then : oRow.Visible = False
As for changing in to mm. These changes can be reflected on your table only when created. That is, you need to delete the table and create it again.
Message 7 of 16
eladm
Hi
this is the part list
after use the code :
not good , I need to remove the units from the rows with the value with the unit
Message 8 of 16
Andrii_Humeniuk
Hope this is what you need. If so, then you need to use this code whenever there are changes to the model.
	Try : oRow.Expanded = True : oRow.Visible = True : Catch : End Try
	Dim oRefRow As DrawingBOMRow = oRow.ReferencedRows(1)
	Dim oRefDoc As Document = oRefRow.BOMRow.ComponentDefinitions(1).Document
		Dim eQty As BOMQuantityTypeEnum = Nothing
		Dim oParam As Inventor.Parameter = Nothing
		Try : oPipeDoc.ComponentDefinition.BOMQuantity.GetBaseQuantity(eQty, oParam)
		Catch : Continue For : End Try
		Dim dLeng As Double = Round(oDDoc.UnitsOfMeasure.ConvertUnits(oParam.Value, "cm", "mm"), 3)
		oRow("QTY").Value = dLeng
Next
Message 9 of 16
A.Acheson
Hi @eladm
This operation  would be far easier if you  convert the pipe units of inches to mm in the family part in content center. What is the end goal in stripping the units and leaving lengths of mm and lengths of inches. A user will assume the units incorrectly and you have the wrong cut list. I use tube and pipe and get help set things up so you don't need to do these funky work arounds.
Is this what you want to achieve in the workaround?
Old
21.7 in
756.920 mm
New
21.7
756.920
How to remove, in a rule loop each cell in that column and find mm and do a string.replace with "".
Regards
Alan
Message 10 of 16
eladm
Hi
The end goal is to remove the units , if a row value : 2 in -> 2 , other row 45mm -> 45
When use tube and pipe you can't change the unit of the pipe.
you don't need to care "  A user will assume the units incorrectly ... " , not "my problem 🙂
Message 11 of 16
A.Acheson
It is possible to change pipe unit globally for the entire pipe family. Place a pipe as custom, changed the units. Go to content center family and replace family template.
If you just want to remove the unit on the partlist row then this mmodification of @Andrii_Humeniuk will do it for "mm". Follow the same principal for "in". Use String replace with the help pagehere. It isn't tested so test on a sample.
Keep in mind when you do this the cell value is now static and will receive no update from the model. Great if you have the model complete but it could lead to future errors.
         If oRow(2).Value.Contains("mm") Then
           oRow(2).Value = Replace(oRow(2).Value, "mm","")
Next
Regards
Alan
Message 12 of 16
eladm
Hi
Can you change the rule , that it will be change other units (not just mm)?
regards
Message 13 of 16
A.Acheson
Just add and  ElseIf statement with the new units.
ElseIf oRow(2).Value.Contains("in") Then
           oRow(2).Value = Replace(oRow(2).Value, "in","")
Regards
Alan
Message 14 of 16
eladm
If I want all the units ?
I add also for m :
       ElseIf oRow(2).Value.Contains("m") Then
           oRow(2).Value = Replace(oRow(2).Value, "m", "")
it didn't convert , only the in & mm was converted
regards
Message 15 of 16
eladm
Hi
the rule work for only tube and pipe parts ? why ? if I add a "simple file (and change the BOM unit in the document setting to m or mm (not each) ) to the assembly . this part will have no affect by the rule
regards
Message 16 of 16
A.Acheson
This if statement here controls what to look for. If you dont need tube and pipe filtering the has interest line is specific to that addin so comment off or delete.
Old
New
If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject  Then
Regards
Alan
