Bounding cylinder
Bounding cylinder
andrew_canfield
Bounding cylinder
andrew_canfield
Hello
Can a bounding cylinder be created from a part using iLogic?
Regards
Andrew
FINET_Laurent
Hello @andrew_canfield,
You question is not very clear. Please elaborate. Can we have a picture of the desired result ?
Thank you & kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
andrew_canfield
Hello Laurent
Not everything is cuboid (outside of Minecraft) for cylindrical  shapes could there be a cylindrical boundary?
I thought about this because of the fine detail included in downloaded electrical plugs & sockets & the detail isn’t needed at 20:1 drawing scale. The simplification tool in Inventor is semi automatic, what is needed for a bit more automation?
Luckily the current job has possibly 30 different size of plug so I’ll just model them & they can include a little more detail than a bounding cylinder.
Still think there’s a use for a tool which can simplify non cuboid shapes.
Thanks for the comment.
Regards
Andrew
