Hide construction surfaces in idw
hello sir,
I am doing drawing in inventor.
In part modeling,some surface file are drawn for reference purpose.
when I make drawing in inventor,what is proper method for hide surface in drawing.?
When in a part or assembly model look for the "Surface Bodies" folder in the browser.
Expand that folder node and right click and uncheck visibilty for each surface you want to turn off.
In a drawing its very much the same except there will be a "Surface Bodies" folder under each view.
Expand the view node > then expand the part node > then expand the surface bodies folder node > right click and uncheck visibility for each surface you want to hide.
