Message 1 of 1
Help with VBA define flat pattern alignment
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am playing around with Inventor 2023, I tried to use ChatGPT and Gemini but I keep running into the same issue. Unable to align sheet base on edge selected in the .IAM model.
Is this even possible to do?
Public Sub AlignFlatPattern_RemoteControl()
Dim oApp As Application: Set oApp = ThisApplication
' 1. Pick the edge from the assembly
Dim oSelectedEdge As Object
Set oSelectedEdge = oApp.CommandManager.Pick(kPartEdgeFilter, "Select a LONG STRAIGHT edge on the Flat Face")
If oSelectedEdge Is Nothing Then Exit Sub
' 2. Identify the Part and open it
Dim oPartDoc As PartDocument
If TypeOf oSelectedEdge Is EdgeProxy Then
Set oPartDoc = oSelectedEdge.ContainingOccurrence.Definition.Document
Else
Set oPartDoc = oSelectedEdge.Parent.Document
End If
' ACTIVATE is required for SendKeys and UI Commands
Dim oFullDoc As PartDocument
Set oFullDoc = oApp.Documents.Open(oPartDoc.FullFileName, True)
oFullDoc.Activate
' 3. Enter Flat Pattern Environment
Dim oSMDef As SheetMetalComponentDefinition: Set oSMDef = oFullDoc.ComponentDefinition
If Not oSMDef.HasFlatPattern Then oSMDef.Unfold
' Late binding the Flat Pattern to avoid 438 errors
Dim oFlatPattern As Object: Set oFlatPattern = oSMDef.FlatPattern
oFlatPattern.Edit
' 4. Find the Native Edge (The one inside the IPT file)
Dim oNativeEdge As Object
Set oNativeEdge = oSelectedEdge.NativeObject
Else
End If
' 5. THE WORKAROUND: Select and "Press the Button"
oFullDoc.SelectSet.Clear
oFullDoc.SelectSet.Select oNativeEdge
' Get the internal command for "Edit Flat Pattern Definition"
Dim oCtrlDef As ControlDefinition
Set oCtrlDef = oApp.CommandManager.ControlDefinitions.Item("SheetMetalFlatPatternEditDefinitionCmd")
' Execute the command (this opens the dialog box)
oCtrlDef.Execute
' 6. Automate the Dialog Box
' We send "Enter" to click 'OK' on the dialog that just popped up
DoEvents
SendKeys "{ENTER}"
DoEvents
' 7. Exit, Save, and Close
oFlatPattern.ExitEdit
oFullDoc.Save
oFullDoc.Close
MsgBox "Flat Pattern aligned successfully."
End Sub
