Help with iLogic (functions, write iProperties and new Parameters)
emanuel.c
Message 1 of 10
emanuel.c
I'm sorry the title is rather vague. There are probably lots of issues with the code, I kind of pasted it together with help from various sources so I'm sure it could be purified and condensed but in truth, it works mostly OK. My issues are:
1. If iProperty "Product" does not exist it should create it with value "xx". Unfortunately it doesn't create it, but throws the error on line 146 "Cannot find a property named "Product". It does create the other iProperties "GS Stock Number" and "STOCK SIZE" if "Product" exists.
2. If the first 2 digits of iProperty "Product" equals "02", "03"... etc. and Parameter FL doesn't exist it should create with value 0. But it doesn't create it. I get an error on line 603, could not find a parameter named: "FL"
The code points to GoExcel and so it may throw errors where it can't find those files, but hopefully someone can help out nonetheless.
Thank you much!
'Code for creating iProperty "GS Stock Number" - which varies in length for each Product / Shape Type and "STOCK SIZE"
'digit 1 is for MATERIAL TYPE. Each content center and sheet metal template has a custome iProperty name "Product" with the specified product type already entered.
	'Otherwise and "xx" will be entered, which can then be modified.
'digits 2,3 is for product SHAPE
'digits 4,5,6 is for plate thickness or wall thickness or diam for round etc.
'digits 7,8,9 is for height dimension (not aplicable for sheet metal, round stock)
'digits 10,11,12 is for width dimension (not aplicable for sheet metals, round stock, flat bars)
Sub Main()
	Dim oPart As PartDocument = ThisDoc.Document
	Dim invdoc As Document
	invdoc = ThisDoc.Document
	Dim oSubType As String = invdoc.SubType
	Dim GS As String = GSNumber(oPart)
	Logger.Info(GS)
	Dim oSS As String = StockSize(oPart)
	Logger.Info(oSS)
	oUserParams = GetUserParams(invdoc) 'Function GetUserParams returns UserParameters Collection
	paraFL = FindParameter(invdoc, "FL") 'Function FindParameter FL - "Final Length"
	Dim oDigit As String = Left(iProperties.Value("Inventor User Defined Properties", "Product"), 2) 'Get the first 2 digits of iProperty "Product"
'Write Parameter FL For certain Product Shapes, Not required For Sheet Metal Parts
Select Case oDigit
	Case "02", "03", "04", "05", "06", "07", "08", "09"
	If paraFL IsNot Nothing Then
		'It exists so move on
	Else
		paraFL = oUserParams.AddByValue("FL", 0, UnitsTypeEnum.kInchLengthUnits)
End Select
End Sub
'Get user parameters collection
Public Function GetUserParams(invdoc As Inventor.Document) As UserParameters
	Dim cd As ComponentDefinition = Nothing
    Select Case invdoc.DocumentType
        Case Is = Inventor.DocumentTypeEnum.kAssemblyDocumentObject
            Dim docAssembly As Inventor.AssemblyDocument = invdoc
            cd = docAssembly.ComponentDefinition
        Case Is = Inventor.DocumentTypeEnum.kPartDocumentObject
            Dim docPart As Inventor.PartDocument = invdoc
            cd = docPart.ComponentDefinition
    End Select
   If cd IsNot Nothing Then
			Dim oParams As Parameters
			oParams = cd.Parameters
			Dim oUserParams As UserParameters
			oUserParams = oParams.UserParameters
            Return oUserParams
	 Return Nothing
End Function
'Create iProperty STOCK SIZE
Private Function StockSize(part As PartDocument) As String
	Dim propertyName As String = "STOCK SIZE"
	Dim PropertyValue As String = getstock(part)
	Dim oCProps As PropertySet = part.PropertySets.Item("Inventor User Defined Properties")
	Dim oSSProp As Inventor.Property
	Dim oExists As Boolean = False
	For Each oCProp As Inventor.Property In oCProps
		If oCProp.Name = propertyName Then
			oSSProp = oCProp
			If PropertyValue = "" Then
				'Do not fill in STOCK SIZE
			Else
				oSSProp.Value = PropertyValue
			oExists = True
	Next
	If oExists = False Then
		oSSProp = oCProps.Add(PropertyValue, propertyName)
	StockSize = oSSProp.Value
End Function
'Define / Create iProperty: "Product"
Private Function Product_iProp(part As PartDocument) As String
	Dim propertyName As String = "Product"
	Dim ProductValue As String = "xx"
	Dim oProductProp As Inventor.Property
			oProductProp = oCProp
			oProductProp.Value = propertyValue
			oExists = True
	Next
		oProductProp = oCProps.Add(ProductValue, propertyName)
End Function
'for writing the "GS Stock Number" iProperty if it doesn't exist
Private Function GSNumber(part As PartDocument) As String
	Dim mat As String = GetMaterialNumber 'used for digit 1
	Dim product As String = GetProduct(part) 'used for digits 2,3
	Dim dim_one As String = Getdim1(part) 'used for digits 4-6
	Dim dim_two As String = Getdim2(part) 'used for digits 7-9
	Dim dim_three As String = Getdim3(part) 'used for digits 10-12
	'Define iProperty: "GS Stock Number"
	Dim propertyName As String = "GS Stock Number"
	'define the value of GS Stock Number
	Dim propertyValue As String
	If iProperties.Value("Inventor User Defined Properties", "Product") = "" Then
		propertyValue = ""
	Else
		propertyValue = mat & product & dim_one & dim_two & dim_three 'These are given by functions bellow
	Dim oGSNumProp As Inventor.Property
			oGSNumProp = oCProp
			oGSNumProp.Value = propertyValue
			oExists = True
	Next
		oGSNumProp = oCProps.Add(propertyValue, propertyName)
	GSNumber = oGSNumProp.Value
End Function
'Get digit 1 for MATERIAL TYPE *************************************************************************************************
Private Function GetMaterialNumber() As String
		GetMaterialNumber = ""
	Else
	'Data is read from Excel "Global Shop Stock Number.xlsx" Sheet "Material". Edit that if needed
	GoExcel.Open("M:\Autodesk Inventor\Ilogic\Global Shop Stock Number.xlsx", "Material")
	Dim partmat As String
	Dim i As Integer
	For i = 3 To 50
		If (GoExcel.CellValue("A" & i)) = iProperties.Material
			partmat = GoExcel.CellValue("B" & i)
			Exit For
	Next
	If String.IsNullOrEmpty(partmat) = True Then
			GetMaterialNumber = "x"
'			MessageBox.Show("Part material is not defined in Excel Spreadsheet" _
'			& vbLf & "Please adjust it to include new material" _
'			& vbLf & "" _
'			& vbLf & "By default an 'x' will be entered", "Part Material Issue")
	GetMaterialNumber = partmat
End Function
'Get digit 2,3 for PRODUCT TYPE ************************************************************************************************
Private Function GetProduct(part As PartDocument) As String
	GetProduct = Left(iProperties.Value("Inventor User Defined Properties", "Product"), 2)
End Function
'Get digitS 4,5,6 for PRODUCT TYPE **********************************************************************************************
Private Function Getdim1(part As PartDocument) As String
	'Get Digits 4,5,6 for SHEET METAL THICKNESS or WALL THICKNESS
	Dim dim1 As String
	Dim oProd As String = iProperties.Value("Inventor User Defined Properties", "Product")
	Select Case oProd
	'Get Thickness for Sheet Metal
	Case "01 Sheet Metal", "26 Diamond Tread"
		GoExcel.Open("M:\Autodesk Inventor\Ilogic\Global Shop Stock Number.xlsx", "Sheet Metal")
		For i = 3 To 100
			If (GoExcel.CellValue("A" & i)) = Parameter("Thickness")
				dim1 = GoExcel.CellValue("B" & i)
		Exit For
		Next
		If String.IsNullOrEmpty(dim1) = True Then
			dim1 = "xxx"
	'Get wall thickness for pipe or DOM
	Case "02 Pipe", "02 DOM"
		GoExcel.Open("M:\Autodesk Inventor\Ilogic\Global Shop Stock Number.xlsx", "Pipe and DOM")
		For i = 3 To 150
			If (GoExcel.CellValue("A" & i)) = Parameter("ParT")
				dim1 = GoExcel.CellValue("C" & i)
		Exit For
		Next
			dim1 = "xxx"
	'Get wall thickness for Angles, Flat Bar, Tubes
	Case "03 Angle", "05 Tube", "05 R Tube", "05 Sq Tube"
		GoExcel.Open("M:\Autodesk Inventor\Ilogic\Global Shop Stock Number.xlsx", "Standard Shape")
		For i = 3 To 100
			If (GoExcel.CellValue("A" & i)) = Parameter("G_T")
		Exit For
		Next
			dim1 = "xxx"
	'Get flat bar thickness
	Case "04 Flat Bar", "09 Sq Bar", "09 Hex"
		For i = 3 To 100
			If (GoExcel.CellValue("A" & i)) = Parameter("G_H")
		Exit For
		Next
			dim1 = "xxx"
	'Get Profile Height for Channels
	'It's 3 digits, so "00" is added before single digit sizes, "00" for double and 3 digits fills it
	Case "06 Channel"
	Dim paramGH As Integer
	paramGH = Parameter("G_H")
		If paramGH <=9 Then
			dim1 = "00" & paramGH
		Else
			If paramGH >=9 And paramGH<=100 Then
				dim1 = "0" & paramGH
			Else
				If paramGH >100 Then
					dim1=paramGH
	'Get Profile Height for Channel Bar Size
	Case "06 Channel Bar"
		For i = 3 To 100
		Exit For
		Next
			dim1 = "xxx"
	'Get Profile Height for Beams
	Case "07 W Beam", "07 S Beam", "07 M Beam", "07 HP Beam"
	paramGH = Parameter("G_H_nom")
		If paramGH <=9 Then
		Else
			If paramGH >=9 And paramGH <=100 Then
			Else
					dim1=paramGH
	'Get Diameter for Round
	Case "08 Round"
		For i = 3 To 100
			If (GoExcel.CellValue("A" & i)) = Parameter("Diam")
		Exit For
		Next
			dim1 = "xxx"
	End Select
	Return dim1
End Function
	'GET DIMENSION 2********************************************************************************************************
Private Function Getdim2(part As PartDocument) As String
	'Get Digit 7,8,9
	Dim dim2 As String
	Select Case oProd
		'Get Pipe nominal diameter
		Case "02 Pipe"
		For i = 3 To 200
			If (GoExcel.CellValue("D" & i)) = Parameter("G_D_Nom")
				dim2 = GoExcel.CellValue("E" & i)
		Exit For
		Next
		If String.IsNullOrEmpty(dim2) = True Then
			dim2 = "xxx"
		'Get DOM diameter
		Case "02 DOM"
		For i = 3 To 200
			If (GoExcel.CellValue("F" & i)) = Parameter("Diam")
				dim2 = GoExcel.CellValue("G" & i)
		Exit For
		Next
			dim2 = "xxx"
		'Get Height dimension of Angles and Tubes
		For i = 3 To 150
			If (GoExcel.CellValue("C" & i)) = Parameter("G_H")
				dim2 = GoExcel.CellValue("D" & i)
		Exit For
		Next
			dim2 = "xxx"
		'Get Height dimension of Flat Bar
		Case "04 Flat Bar"
		For i = 3 To 150
			If (GoExcel.CellValue("A" & i)) = Parameter("G_W")
				dim2 = GoExcel.CellValue("B" & i)
		Exit For
		Next
			dim2 = "xxx"
		'Get Profile Mass for Channels and Beams
		'It only takes the integer part of the number
		Case "06 Channel", "07 W Beam", "07 S Beam", "07 M Beam", "07 HP Beam"
		Dim paramGW As Integer
		paramGW = Parameter("G_Weight")
			If paramGW <=9 Then
				dim2 = "00" & paramGW
			Else
				If paramGW >=9 And paramGW<=100 Then
					dim2 = "0" & paramGW
				Else
					If paramGW >100 Then
						dim2=paramGW
		'Get Profile Width for Channel Bar Size
			For i = 3 To 20
				If (GoExcel.CellValue("F" & i)) = Parameter("b")
			Exit For
			Next
				dim2 = "xxx"
	End Select
	Return dim2
End Function
'Get Dimension 3 ************************************************************************************************************************
Private Function Getdim3(part As PartDocument) As String
	'Get Digit 10,11,12
	Dim dim3 As String
	Select Case oProd
		'Get width dimension for Angle or Tube
		For i = 3 To 150
			If (GoExcel.CellValue("C" & i)) = Parameter("G_W")
				dim3 = GoExcel.CellValue("D" & i)
		Exit For
		Next
		If String.IsNullOrEmpty(dim3) = True Then
			dim3 = "xxx"
			For i = 3 To 20
				If (GoExcel.CellValue("A" & i)) = Parameter("t1")
					dim3 = GoExcel.CellValue("B" & i)
			Exit For
			Next
				dim3 = "xxx"
	Case Else
			dim3 =""
	End Select
	Return dim3
End Function
'See if parameter FL exists
Public Function FindParameter(invdoc As Inventor.Document, strParameter As String) As Parameter
End Select
    For Each param As Inventor.Parameter In cd.Parameters
        If param.Name = strParameter Then
            Return param
    Next
	Return Nothing
End Function
'Write STOCK SIZE for each part shape
Private Function getstock(part As PartDocument) As String
Select Case iProperties.Value("Inventor User Defined Properties", "Product")
		Dim opart As PartDocument = ThisDoc.Document()
		Dim smCompDef As SheetMetalComponentDefinition = opart.ComponentDefinition
		Dim smlength As Double
		Dim smwidth As Double
		Dim oSMthk As Double = Parameter("Thickness")
		If smCompDef.HasFlatPattern Then
			smlength = (smCompDef.FlatPattern.Length() + oSMthk) / 2.54 'add thickness for plasma cut kerf. Divide cm to inches
			smwidth = (smCompDef.FlatPattern.Width() + oSMthk) / 2.54
		Else
			Try
			smCompDef.Unfold()
			Catch
			End Try
		Dim AreaPronest As Double = smlength * smwidth / 144
		If Parameter("Thickness") >= 0.1875 Then
				getstock ="Plate, " & Format(oSMthk, "0.000") & " thk x " & Format(AreaPronest, "0.00") & " ft^2"
			Else
				getstock ="Sheet Metal, " & Format(oSMthk, "0.000") & " thk x " & Format(AreaPronest, "0.00") & " ft^2"
	Case "27 Expanded Metal"
		Dim emstock As String = Parameter("stock")
		Dim AreaEM As Single = ((SheetMetal.FlatExtentsLength + .5 in) * (SheetMetal.FlatExtentsWidth + .5 in)) / 144
		getstock = "Expanded, " & emstock & ", " & Format(AreaEM, "0.00") & " ft^2"
	Case "02 Pipe"
		Dim oPipeD As Double = Parameter("G_D_Nom")
		oL = FormatAsFraction(oPipeD)
		Dim pFL As Double = Parameter("FL")
		getstock = "Pipe, " & oL & " sch." & Parameter("Schedule") & " x " & RoundToFraction(pFL, 1/16, RoundingMethod.Round)
	Case "02 DOM"
		Dim domD As Double = Parameter("Diam")
		Dim domID As Double = Parameter("ID")
		Dim dFL As Double = Parameter("FL")
		getstock = "DOM, " & Format(domD, "0.00") & " OD x " & Format(domID, "0.00") & " ID x " & RoundToFraction(dFL, 1/16, RoundingMethod.Round)
	Case "03 Angle"
		Dim Athk As Double = Parameter("G_T")
		Dim AW As Double = Parameter("G_W")
		Dim AH As Double = Parameter("G_H")
		Dim AFL As Double = Parameter("FL")
		'getstock = "L " & Format(AW, "0.00") & " x " & Format(AH, "0.00") & " x " & Format(Athk, "0.00") & " x " & RoundToFraction(AFL, 1/16, RoundingMethod.Round)
		getstock = "L " & RoundToFraction(AW, 1 / 16, RoundingMethod.Round) & " x " & RoundToFraction(AH, 1 / 16, RoundingMethod.Round) & " x " & RoundToFraction(Athk, 1 / 16, RoundingMethod.Round) & " x " & RoundToFraction(AFL, 1/16, RoundingMethod.Round)
	Case "04 Flat Bar"
		Dim FBthk As Double = Parameter("G_H")
		Dim FBwidth As Double = Parameter("G_W")
		Dim FFL As Double = Parameter("FL")
		'getstock = "Flat Bar, " & Format(FBwidth, "0.00") & " x " & Format(FBthk, "0.00") & " x " & RoundToFraction(FFL, 1/16, RoundingMethod.Round)
		getstock = "Flat Bar, " & RoundToFraction(FBwidth, 1/16, RoundingMethod.Round) & " x " & RoundToFraction(FBthk, 1/16, RoundingMethod.Round) & " x " & RoundToFraction(FFL, 1/16, RoundingMethod.Round)
	Case "05 R Tube"
		Dim RTthk As Double = Parameter("G_T")
		Dim RTH As Double = Parameter("G_H")
		Dim RTW As Double = Parameter("G_W")
		Dim RFL As Double = Parameter("FL")
		If RTH < 2 Then
			getstock = "R Tube " & Format(RTH, "0.00") & " x " & Format(RTW, "0.00") & " x " & Format(RTthk, "0.00") & " x " & RoundToFraction(RFL, 1 / 16, RoundingMethod.Round)
		Else
			getstock = "R Tube " & RoundToFraction(RTH, 1 / 16, RoundingMethod.Round) & " x " & RoundToFraction(RTW, 1 / 16, RoundingMethod.Round) & " x " & RoundToFraction(RTthk, 1 / 16, RoundingMethod.Round) & " x " & RoundToFraction(RFL, 1 / 16, RoundingMethod.Round)
	Case "05 Sq Tube"
		Dim STthk As Double = Parameter("G_T")
		Dim STH As Double = Parameter("G_H")
		Dim STW As Double = Parameter("G_W")
		Dim SFL As Double = Parameter("FL")
		If STH < 2 Then
			getstock = "Sq Tube " & Format(STH, "0.00") & " x " & Format(STW, "0.00") & " x " & Format(STthk, "0.00") & " x " & RoundToFraction(SFL, 1 / 16, RoundingMethod.Round)
		Else
			getstock = "Sq Tube " & RoundToFraction(STH, 1/16, RoundingMethod.Round) & " x " & RoundToFraction(STW, 1/16, RoundingMethod.Round) & " x " & RoundToFraction(STthk, 1/16, RoundingMethod.Round) & " x " & RoundToFraction(SFL, 1/16, RoundingMethod.Round)
	Case "06 Channel"
		Dim CFL As Double = Parameter("FL")
		getstock = "C " & Parameter("G_H") & "x" & Parameter("G_Weight") & " x " & RoundToFraction(CFL, 1/16, RoundingMethod.Round)
		Dim CBH As Double = Parameter("G_H")
		Dim CBb As Double = Parameter("b")
		Dim CBt As Double = Parameter("t1")
		Dim cFL As Double = Parameter("FL")
		getstock = "C Bar " & Format(CBH, "0.00") & " x " & Format(CBb, "0.00") & " x " & Format(CBt, "0.00") & " x " & RoundToFraction(cFL, 1/16, RoundingMethod.Round)
	Case "07 W Beam"
		Dim WFL As Double = Parameter("FL")
		getstock = "W " & Parameter("G_H_nom") & "x" & Parameter("G_Weight") & " x " & RoundToFraction(WFL, 1/16, RoundingMethod.Round)
	Case "07 S Beam"
		getstock = "S " & Parameter("G_H_nom") & "x" & Parameter("G_Weight") & " x " & RoundToFraction(SFL, 1/16, RoundingMethod.Round)
	Case "07 M Beam"
		Dim MFL As Double = Parameter("FL")
		getstock = "M " & Parameter("G_H_nom") & "x" & Parameter("G_Weight") & " x " & RoundToFraction(MFL, 1/16, RoundingMethod.Round)
	Case "07 HP Beam"
		Dim HPFL As Double = Parameter("FL")
		getstock = "HP " & Parameter("G_H_nom") & "x" & Parameter("G_Weight") & " x " & RoundToFraction(HPFL, 1/16, RoundingMethod.Round)
	Case "08 Round"
		Dim RDiam As Double = Parameter("Diam")
		getstock = "Round, " & Format(RDiam, "0.00") & " D x " & RoundToFraction(RFL, 1/16, RoundingMethod.Round)
	Case "09 Sq Bar"
		Dim HW As Double = Parameter("G_H")
		Dim sFL As Double = Parameter("FL")
		getstock = "Sq Bar, " & Format(HW, "0.00") & " x " & Format(HW, "0.00") & " x " & RoundToFraction(sFL, 1/16, RoundingMethod.Round)
	Case "09 Hex"
		Dim hFL As Double = Parameter("FL")
		getstock = "Hex Bar, " & Format(HW, "0.00") & " x " & RoundToFraction(hFL, 1/16, RoundingMethod.Round)
	Case Else
		getstock = ""
	End Select
End Function
Replies (9)
Message 2 of 10
WCrihfield
Hi @emanuel.c.  Your function for creating that custom iProperty looks OK to me.  But after some review, I believe the problem is that you are actually attempting to get the value of that iProperty earlier in the timeline flow of your code than that function is being used to ensure its existence.
Edit:  In fact, I don't see anywhere within the rest of your code where you are calling that function (Product_iProp) to run at all.
Edit 2:  Also, you have that set-up as a Function, that is supposed to return a String, but you don't have any 'Return' lines within that Function to return a String.  So, if you don't really need to return anything from that routine, you could just switch it to a Sub, then get rid of the 'As String' at the end of its definition line.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 10
emanuel.c
I know, I'm attempting to get the "Product" value in various functions later on, but I can't figure out why it's not creating it when it doesn't exist... So I got rid of most of the functions to simplify things, if you would take a look at it now. And it still doesn't create the iProperty "Product" even though it's not referenced later on. Thank you!
Sub Main()
	Logger.Info(GS)
End Sub
			oExists = True
	Next
End Function
	Dim mat As String = "00" 'used for digit 1
	Dim product As String = "22" 'used for digits 2,3
	Dim dim_one As String = "333" 'used for digits 4-6
	Dim dim_two As String = "444" 'used for digits 7-9
	Dim dim_three As String = "555" 'used for digits 10-12
		propertyValue = ""
	Else
			oGSNumProp = oCProp
			oExists = True
	Next
End Function
Message 4 of 10
jjstr8
I think what @WCrihfield initially referred to is the first line in your GetMaterialNumber function.  Should it really be the "Product" custom iProperty or actually something else?
Message 5 of 10
emanuel.c
I think that works OK. Basically if "Product" is empty then GetMaterialNumber is left empty too. But I got rid of all the functions to weed out the error and it still doesn't write the new iproperty "Product".
Message 6 of 10
WCrihfield
Hi @emanuel.c.  That code you just posted, even though it 'contains' the function called "Product_iProp", you are not calling that function to run anywhere within the rest of you code.  In order for that function to work (do something), you need to call it to run somewhere either within the Sub Main area, or within the GSNumber function code area.  That iLogic only snippet 'iProperties.Value()' will only create an iProperty automatically for you if you are directly setting an initial value to it.  So, when you are using that iProperties.Value line within your GSNumber function, it is trying to get the value from an iProperty which does not exist yet, and that line will not automatically create it for you, because it is checking its 'existing' value, instead of setting a value to it.
I modified your short version code here to show you the changes I believe you need.  I changed the "Product_iProp" function to a Sub, because we were not making use of the String it was supposed to return, and I don't know what String you were intending to return from it (maybe its Value?).  Then I included a line within your Sub Main area to call that Sub to run, before your GSNumber function runs, so that it will have already created the needed iProperty.
Sub Main()
	'this next line is going to 'run' or 'call' the custom Sub below to run
	Product_iProp(oPart)
	'now that iProperty should exist when calling the other Subs/Functions to run later
	'much the same way that this next line is causing your 'GSNumber' function to run
	Logger.Info(GS)
End Sub
Private Sub Product_iProp(part As PartDocument)
			oExists = True
	Next
End Sub
		propertyValue = ""
	Else
			oGSNumProp = oCProp
			oExists = True
	Next
End Function
Wesley Crihfield
Message 7 of 10
emanuel.c
Yes, thanks so much for running through it. I was not seeing it but that part works well now.
Do you see where the issue is on number 2?
Message 8 of 10
WCrihfield
I wasn't 100% sure what you meant by 'number 2' there, but I assumed you meant the second main problem mentioned at the top of this post, where you were having trouble finding the parameter named "FL".  I was going to ask what version of Inventor you were using, but I looked at a couple of your other posts and saw a screen captured image you posted which included a ModelStates folder in the model browser tree, which answered my question (you are using 2022).  So, knowing that, I suspected that there may be model states involved, and so we might have to take that into account in various places within this code.  So, to start with, I changed your first line of code, which defines the part document.  I changed it from using 'ThisDoc.Document' to using 'ThisDoc.FactoryDocument'.  Then I focused on your function called 'FindParameter', to get it updated a bit with this in mind.  To show the resulting code in a usable way, I created a new rule with just those two parts in it, so you can test their functionality, before adapting them into your main larger code.
Sub Main
	Dim oPart As PartDocument = ThisDoc.FactoryDocument
	Dim paraFL As Inventor.Parameter = FindParameter(oPart, "FL") 'FL - "Final Length"
	If paraFL Is Nothing Then
		MsgBox("Could not find the parameter named 'FL'.", vbExclamation, "")
		'Exit Sub
	Else
		MsgBox("The current Value of the parameter named 'FL' is:  " & paraFL.Expression, , "")
End Sub
Function FindParameter(invdoc As Inventor.Document, strParameter As String) As Inventor.Parameter
	If invdoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or _
		invdoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		If invdoc.ComponentDefinition.IsModelStateMember Then
			invdoc = invdoc.ComponentDefinition.FactoryDocument
		oParams = invdoc.ComponentDefinition.Parameters
	Else
		Return Nothing
    For Each oParam As Inventor.Parameter In oParams
        If oParam.Name = strParameter Then
            Return oParam
    Next
	Return Nothing
End Function
Wesley Crihfield
Message 9 of 10
emanuel.c
Thank you for helping. Yup I'm on the latest 2022 version of Inventor 🙂 So the find parameter function works well, but unfortunately the FL parameter is still not created if it doesn't find it. (I'd like for it to be automatically added, even if I have to later modify it's value, to save me the little time of creating the new parameter, which can add up if I have many parts).
I'm not sure where it's calling it, or why the line under the first Else doesn't write the "FL", 0 parameter. Please see below:
Sub Main
		'Exit Sub
	Else
End Sub
    End Select
            Return oUserParams
	 Return Nothing
End Function
	Else
		Return Nothing
            Return oParam
    Next
	Return Nothing
End Function
Message 10 of 10
emanuel.c
Well, I'm not sure where my mistake was. Maybe I was calling GSNumber and StockSize before the paraFL? Not sure... but I edited the first Sub Main as such and it works perfectly.
Thank you Wesley for your help!
Sub Main()
	Product_iProp(oPart) 'calling the Product_iProp function
	Dim invdoc As Document = ThisDoc.FactoryDocument
	paraFL = FindParameter(invdoc, "FL") 'Function FindParameter returns the looked for parameter: FL - "Final Length"
	'Write parameter FL for certain Product Shapes, not required for all parts
	Select Case oDigit
		Else
			'It already exists
	End Select
	Logger.Info(GS)
	Logger.Info(oSS)
End Sub
