Help to insert SketchSymbol from Library/Template
ngdnam88
ngdnam88
Dears,
I'm using this code to insert a sketch symbol from Library/Template file to working drawing. Please help me to check and give me another solution?
Dim oDOC As Inventor.DrawingDocument = _InventorApp.ActiveDocument
Dim oSSDefs As SketchedSymbolDefinitions = oDOC.SketchedSymbolDefinitions
Dim oLibrary As SketchedSymbolDefinitionLibrary = oSSDefs.SketchedSymbolDefinitionLibraries.Item("SketchSymbols.idw")
Dim wSSDef As SketchedSymbolDefinition = Nothing
Try
	wSSDef = oDOC.SketchedSymbolDefinitions.Item("ABC")
Catch ex As Exception
	wSSDef = oSSDefs.AddFromLibrary(oLibrary, "ABC", True)
End Try
For Each ChkObject As Object In oDOC.SelectSet
	If ChkObject.Type() = ObjectTypeEnum.kLinearGeneralDimensionObject Then
		Dim wPoint As Inventor.Point2d = ChkObject.DimensionLine.MidPoint
		Dim wSketchSymbol As SketchedSymbol = oDOC.ActiveSheet.SketchedSymbols.Add(wSSDef, wPoint, 0, 1, Nothing)
		wSketchSymbol.Static() = True
	End If
Next
My issue is: If SketchSymbol existed, it'll be insert corrected at the first time. If SketchSymbol doesn't existed, the SketchSymbol 'll copy to current drawing only and doesn't used at the first time - It'll insert at the second time when code run again!
I don't know why. Could you please help me. Thanks!
JelteDeJong
The problem here is that you use the selection set. the selection set is cleared when you add a SketchedSymbol to you drawing.
To prevent this you could first look at your selection set and add all dimensions to a new list. Then get/add the sketched symbol. And then you only need to loop over the new list of dimensions. Something like this would work.
Dim oDOC As Inventor.DrawingDocument = ThisApplication.ActiveDocument
' create and fill a list of LinearGeneralDimension
Dim dimensons As New List(Of LinearGeneralDimension)
        dimensons.Add(ChkObject)
    End If
Next
Try
End Try
' loop over the list of LinearGeneralDimension
For Each dimenson As LinearGeneralDimension In dimensons
    Dim wPoint As Inventor.Point2d = dimenson.DimensionLine.MidPoint
Next
Jelte de Jong
Blog: hjalte.nl - github.com
ngdnam88
Thanks @JelteDeJong
I got it. It's working now!
