Help Tip text to Marco , is this possible ?
Darkforce_the_ilogic_guy
Advisor Advisor
I have made many special design button using the VBA Marco in inventor. Is it possible to add help text to the button? when mouse moving over it ? or is that any other good way to help people understand what the button do?
FINET_Laurent
Morning,
Maybe this thread helps you out.
https://forums.autodesk.com/t5/inventor-customization/tooltip-on-button/td-p/757447
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
