Help: iLogic/VBA Code Get Body'/Feature' Name then Add the Leader Text in the Drawing
ngdnam88
ngdnam88
Dears,
I'm trying find the iLogic/VBA Code that can get name of Body/Feature then create the Text Leader as the picture:
Is it possible?
I think the way to done this (but I didn't know how to code them):
+ Create the Leader Text with any Char.
+ Rule can filter select Body/Feature
+ Take name's of Body/Feature
+ Select the Leader Text and correct it with Body'/Feature' name
Thanks you very much!
Michael.Navara
Here is a sample iLogic code, where you can start
Dim drw As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = drw.ActiveSheet
'Pick some linear edge
'For diferent edge type you need to modify the code for creating of connectionPoint
Dim pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Pick drawing line")
Dim curveSegment As DrawingCurveSegment = pick
If curveSegment.GeometryType <> Curve2dTypeEnum.kLineSegmentCurve2d Then
    MsgBox("This is not a line segment")
    Return
'Connection point to drawing curve segment
Dim curveGeometry As LineSegment2d = curveSegment.Geometry
Dim connectionPoint As GeometryIntent = sheet.CreateGeometryIntent(curveSegment.Parent, curveGeometry.MidPoint)
'Position of text
Dim textPoint As Point2d = curveGeometry.MidPoint
textPoint.X +=1
textPoint.Y +=1
'Create leader points for general note
Dim leaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection()
leaderPoints.Add(textPoint)
leaderPoints.Add(connectionPoint)
'Get body name
Dim partEdge as Edge = curveSegment.Parent.ModelGeometry
Dim surfaceBody As SurfaceBody = partEdge.Parent
dim bodyName = surfaceBody.Name
'Create leader note
sheet.DrawingNotes.LeaderNotes.Add(leaderPoints, bodyName)
ngdnam88
Thanks @Michael.Navara
It's working perfectly.
Can we change/apply the the Format Style before place the text leader? I wanna use an other one for this leader text.
