counting named features (holes, cuts) in patterns
wbarnardGTEV5
wbarnardGTEV5
we make holes in parts in three ways, punching, drilling, and burning.  i want to be able to pull this data out of large assembly boms later down the road, so im trying to use ilogic in my start parts to help with cost analysis later.
workflow will be that if holes are "PUNCHED", "DRILLED" OR "BURNED" the user will simply name the feature so it starts with one of those key words,  i have the macro just about working, except for where it comes to counting the named features once used in a pattern.
'assume part document
Dim oDoc As PartDocument = ThisDoc.Document
'Set oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
'assume rectangular pattern
Dim oRectPatterns As RectangularPatternFeatures = oDef.Features.RectangularPatternFeatures
'assume circular pattern
Dim oCircPatterns As CircularPatternFeatures = oDef.Features.CircularPatternFeatures
Dim A As Integer = 0
For Each BFeat In oDef.Features.ExtrudeFeatures
	If BFeat.Name.Contains("BURN") Then A = A + 1
Next
iProperties.Value("Custom", "BRN_HOLES") = A
' Calc patterned burned holes
Dim B As Integer = 0 'counter
For Each oRPPB As RectangularPatternFeature In oRectPatterns
	'consider only patterns CONTAINING NAME
	If oRPPB.ParentFeatures.Item(1).Name.Contains("BURN") Then Continue For
	For Each oFPEPB As FeaturePatternElement In oRPPB.PatternElements
		If oFPEPB Is active Then B += 1
	Next
Next
For Each oCPPB As CircularPatternFeature In oCircPatterns
	If oCPPB.ParentFeatures.Item(1).Name.Contains("BURN") Then Continue For
	For Each oFPEPB As FeaturePatternElement In oCPPB.PatternElements
	Next
Next
iProperties.Value("Custom", "PTN_BRNS") = B
Dim C As Integer = 0 'counter
For Each oRPbp As RectangularPatternFeature In oRectPatterns
	'consider only hole patterns
	If oRPbp.ParentFeatures.Item(1).Name.Contains("BURN") Then C += 1
Next
For Each oCPbp As CircularPatternFeature In oCircPatterns
	If oCPbp.ParentFeatures.Item(1).Name.Contains("BURN") Then C += 1
Next
iProperties.Value("Custom", "BRN_PTNS") = C
'WORK WITH DRILLED HOLES
Dim D As Integer = 0
For Each DFeat In oDef.Features.ExtrudeFeatures
	If DFeat.Name.Contains("DRILL") Then D = D + 1
Next
iProperties.Value("Custom", "DRL_HOLES") = D
' Calc patterned DRILLED holes
Dim E As Integer = 0 'counter
For Each oRPPD As RectangularPatternFeature In oRectPatterns
	If oRPPD.ParentFeatures.Item(1).Name.Contains("DRILL") Then Continue For
	For Each oFPEPD As FeaturePatternElement In oRPPD.PatternElements
		If oFPEPD Is Active Then E += 1
	Next
Next
For Each oCPPD As CircularPatternFeature In oCircPatterns
	If oCPPD.ParentFeatures.Item(1).Name.Contains("DRILL") Then Continue For
	For Each oFPEPD As FeaturePatternElement In oCPPD.PatternElements
	Next
Next
iProperties.Value("Custom", "PTN_DRLS") = E
Dim F As Integer = 0 'counter
For Each oRPDp As RectangularPatternFeature In oRectPatterns
	If oRPDp.ParentFeatures.Item(1).Name.Contains("DRILL") Then F += 1
Next
For Each oCPDp As CircularPatternFeature In oCircPatterns
	If oCPDp.ParentFeatures.Item(1).Name.Contains("DRILL") Then F += 1
Next
iProperties.Value("Custom", "DRL_PTNS") = F
'WORK WITH PUNCHED HOLES
Dim G As Integer = 0
For Each PFeat In oDef.Features.ExtrudeFeatures
	If PFeat.Name.Contains("PUNCH") Then G = G + 1
Next
iProperties.Value("Custom", "PUN_HOLES") = G
' Calc patterned punched holes
Dim H As Integer = 0 'counter
For Each oRPPP As RectangularPatternFeature In oRectPatterns
	If oRPPP.ParentFeatures.Item(1).Name.Contains("PUNCH") Then Continue For
	For Each oFPEPP As FeaturePatternElement In oRPPP.PatternElements
		If Feature.IsActive(oRPPP)=True Then H += 1
	Next
Next
For Each oCPPP As CircularPatternFeature In oCircPatterns
	If oCPPP.ParentFeatures.Item(1).Name.Contains("PUNCH") Then Continue For
	For Each oFPEPP As FeaturePatternElement In oCPPP.PatternElements
		If Feature.IsActive(oCPPP)=True Then H += 1
	Next
Next
iProperties.Value("Custom", "PTN_PUNS") = H
Dim J As Integer = 0 'counter
For Each oRPPPAT As RectangularPatternFeature In oRectPatterns
	If oRPPPAT.ParentFeatures.Item(1).Name.Contains("PUNCH") Then J += 1
Next
For Each oCPPPAT As CircularPatternFeature In oCircPatterns
	If oCPPPAT.ParentFeatures.Item(1).Name.Contains("PUNCH") Then J += 1
Next
iProperties.Value("Custom", "PUN_PTNS") = J
BURNCOUNT = (iProperties.Value("Custom", "BRN_HOLES") + iProperties.Value("Custom", "PTN_BRNS")) -iProperties.Value("Custom", "BRN_PTNS")
iProperties.Value("Custom", "BURNED HOLES") = BURNCOUNT
DRILLCOUNT = (iProperties.Value("Custom", "DRL_HOLES") + iProperties.Value("Custom", "PTN_DRLS")) -iProperties.Value("Custom", "DRL_PTNS")
iProperties.Value("Custom", "DRILLED HOLES") = DRILLCOUNT
PUNCHCOUNT = (iProperties.Value("Custom", "PUN_HOLES") + iProperties.Value("Custom", "PTN_PUNS")) -iProperties.Value("Custom", "PUN_PTNS")
iProperties.Value("Custom", "PUNCHED HOLES") = PUNCHCOUNT
TOTALCOUNT = iProperties.Value("Custom", "DRILLED HOLES") + iProperties.Value("Custom", "BURNED HOLES") + iProperties.Value("Custom", "PUNCHED HOLES")
iProperties.Value("Custom", "HOLES TOTAL") = TOTALCOUNT
wbarnardGTEV5
specifically, the issue is in these loops.  it will not count the consumed features
	Next
Next
	Next
WCrihfield
It's a little difficult to debug remotely but when I look at those two loops you pointed out, the final line within the loop that is supposed to add to the count does not look valid to me.
This line:
does not appear to be doing anything, because 'Is active' is not a valid property/method of a FeaturePatternElement (Link1, Link2).  You could try something like this in its place, which would be a similar sounding test:
If oFPEPB.Suppressed = False Then B += 1
Wesley Crihfield
(Not an Autodesk Employee)
wbarnardGTEV5
Thank you!
It is now working, I also needed to invert part of the selection.
resulting loop example
For Each oRPb As RectangularPatternFeature In oRectPatterns
	If Not oRPb.ParentFeatures.Item(1).Name.Contains("BURN") Then Continue For
	For Each oFPEb As FeaturePatternElement In oRPb.PatternElements
		If oFPEb.Suppressed = False Then B += 1
	Next
Next
