Help: iLogic Format Text for 3D Annotate Notes (General Note)
ngdnam88
Message 1 of 13
ngdnam88
Dear All,
Please help me the iLogic Code can setting the Format Text for 3D Annotate Notes (General Note)? Thanks,
Replies (12)
Message 2 of 13
theo.bot
The Notes contains formatted text. To create the formatted text correctly is maybe not that easy. So i would do it like this:
create a general note, link all the parameters and format the text as you would like.
Then run this small rule (make sure the ilogic logger tab is visible)
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
'Logger.Info(oDoc.ComponentDefinition.ModelAnnotations.ModelGeneralNotes.Item(1).Definition.Text.FormattedText)
Then copy the text from the logger screen:
now you can create a external rule and use (paste)  your formatted text:
oFormat = "Partnumber:<Property Document='model' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property><Br/>Material: <Property Document='model' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='20'>MATERIAL</Property><Br/>Mass: <PhysicalProperty PhysicalPropertyID='72449' Precision='2'>MASS</PhysicalProperty>"
'create definition
Dim oGennotedef As ModelGeneralNoteDefinition
oGennotedef= oDoc.ComponentDefinition.ModelAnnotations.ModelGeneralNotes.CreateDefinition(oFormat, True, ScreenQuadrantEnum.kLowerRightQuadrant)
'add to model
Dim oGennote As ModelGeneralNote
oGennote = oDoc.ComponentDefinition.ModelAnnotations.ModelGeneralNotes.Add(oGennotedef)
Message 3 of 13
ngdnam88
Thanks @theo.bot
How about the setting Font + Text Size?. Could you please help me. Thanks,
Message 4 of 13
theo.bot
It works the same. By default the text style is defines the font and size. But if you make changes to your first definition than the formatted text will include this info:
Message 5 of 13
ngdnam88
Thanks you very much!
Message 6 of 13
cparnellCDZ7D
@theo.bot, since I don't know iLogic I am not sure if post will help me. I am trying to find a way to automate 3D Annotate to default to, Type: Standard iProperties and Properties: PART NUMBER.
I created a routine with your code:
I ran it with iLogic Log dialog box showing and got the following:
Error Message:
Error on line 2 in rule: Annotate Part #, in document: HR-AY-0452.iam
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
More Info:
System.InvalidCastException: Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.PartDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D463-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
at ThisRule.Main() in external rule: Annotate Part #:line 2
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Not sure what is going on. Would you be willing to help me out?
Autodesk Inventor Professional 2022
64-Bit Edition
Build: 350, Release: 2033.3 - Date: Wed 04/06/2022
Thank you for any help!
Have a great weekend.
Message 7 of 13
theo.bot
@cparnellCDZ7D
It's because oDoc is declared as Part document and you are running it in a assembly.
You can update it to make it work in parts and assemblies:
Dim oDoc As Document
Message 8 of 13
cparnellCDZ7D
theo.bit
Thank you for your help!!
I changed my file to what you gave me.
I generated my Format Text, have iLogic Log open. When I ran the routine, nothing shows in the iLogic Log window.
Thank you again.
Message 9 of 13
theo.bot
@cparnellCDZ7D
It looks like you created a leader note, not a general note.
If you want to get the leader note info you could use something like this:
Logger.Info(oDoc.ComponentDefinition.ModelAnnotations.ModelLeaderNotes.Item(1).Definition.Text.FormattedText)
Message 10 of 13
cparnellCDZ7D
First, thank you for your help.
Thank you for the update. Still trying to figure out the rest.
If you don't mind, this is what I have.
oFormat = "Property Document='model' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property"
'create definition
Dim oGennotedef As ModelLeaderNoteDefinition
oGennotedef= oDoc.ComponentDefinition.ModelAnnotations.ModelLeaderNotes.CreateDefinition(oFormat, True, ScreenQuadrantEnum.kLowerRightQuadrant)
'add to model
oGennote = oDoc.ComponentDefinition.ModelAnnotations.ModelLeaderNotes.Add(oGennotedef)
'I changed ModelGeneralNoteDefinition to ModelLeaderNoteDefinition line 8
'I changed .ModelGeneralNotes. to .ModelLeaderNotes. on line 9 & 12
'From iLogic Log
'Property Document='model' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='5'>PART NUMBER</Property
'Get error on line 9.
'Error message
'Error on line 9 in rule: Annotate Part #, in document: 04.0-SSB-SSW-R0AA.iam
'Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))
'More Info
'System.Runtime.InteropServices.COMException (0x80020005): Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))
' at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
' at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
' at ThisRule.Main() in external rule: Annotate Part #:line 9
' at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
' at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Message 11 of 13
theo.bot
@cparnellCDZ7D ,
You can't simply replace parts of the codes, because ModelGeneralnotes have different inputs then ModelLeadernodes. The generalNotes are easier, because the definition will require less input. With leader notes you need to define the annotation plane, associated geometry etc.
Check the API help to find out what inputs are required in detail:
Inventor 2023 Help | ModelGeneralNotes.Add Method | Autodesk
Inventor 2023 Help | ModelLeaderNotes.Add Method | Autodesk
Message 12 of 13
cparnellCDZ7D
Thank you again. I'll keep working on it.
Message 13 of 13
vyivanchikov
Good day, everyone!
Can you please tell me how in the environment to pull more
G_L and G_B user data
