Help I'm stuck with a rule code
Message 1 of 1
I have a rule for create a drawing automatic from a part. that works well
But now I want to make a loop that ilogic make a idw for each part in my assembly... two options are acceptable either all in one sheet or for each part a sheet...
What's wrong?
First the code without loop
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawingDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
ViewScale = 1/1
'vraag?
Vraag1=MsgBox("wil je starten met 2d's maken?", vbYesNo,"Laserwerk")
If Vraag1 = vbYes Then
    oPartDoc = ThisDoc.Document
    'locatie van de template
    oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\00-LIBRARY\99-Templates\standaard.idw", True)
    ' oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "", True)
    oSheet = oDrawingDoc.Sheets.Item(1)
    'plaats op sheet bepalen
    oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(10, 10) ' top
	oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, ViewScale,kTopViewOrientation, kHiddenLineDrawingViewStyle, "Default")
End If
my trial
Dim oSheet As sheet
ViewScale = 1/20
'vraag?
vraag1=MsgBox("wil je starten met 2d's maken?", vbYesNo,"Laserwerk")
If vraag1 = vbYes Then
    oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\00-CONSTRUX LIBRARY\99-Templates\Poductietekening standaard.idw", True)
    oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(20, 20) ' top
End If
'------- start of ilogic ------
'vraag?
    oDrawingDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\00- LIBRARY\99-Templates\ standaard.idw", True)
End If
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
                'look at only part files
                 If docFile.DocumentType = kPartDocumentObject Then
            'format  file name
                Dim FNamePos As Long
                FNamePos = InStrRev(docFile.FullFileName, "\", -1)
            Dim docFName As String
                End If
Next
iLogicVb.UpdateWhenDone = True
'------- end of ilogic ------
thanks al lot
Replies (0)
