HELP!How to change color that the "Interference Analyze" tool identifies with
Hi all,
I was wondering if someone knows how to change the color that the "Interference Analyze" tool identifies with??
I recently converted from 2010 to Inventor 2011 Pro. 2010 had a Dark Translucent Red which was extremely helpful. 2011 has a Light Translucent Red which is extremely difficult to make out ( I have a massive assembly). Identifying these fouls/interferences is vital to my job.
I tried Styles Editor, View Styles, Application/Document Settings, and even part manipulation! (bah!)
You have know Idea how much I would appreciate the help.
Please let me know if you have questions.
Thanks in advance!
OJ
HII-NNS
jdkriek
The following iLogic code from Curtis Waguespack is what I like to use
Sub Main
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oAsmDoc.ComponentDefinition
' Add each occurrence in the assembly to the object collection.
Dim oCheckSet As ObjectCollection
oCheckSet= ThisApplication.TransientObjects.CreateObjectCollection
Dim oOcc As ComponentOccurrence
For Each oOcc In oAsmCompDef.Occurrences
oCheckSet.Add (oOcc)
Next
' Call the AnalyzeInterference method, passing in a single
' collection. This will cause it to compare everything against
' everything else.
Dim oResults As InterferenceResults
oResults = oAsmCompDef.AnalyzeInterference(oCheckSet)
' Display the results of the interference.
MessageBox.Show(oResults.Count & " Interferences found ","iLogic")
Dim oResult As InterferenceResult
Dim iCount As Integer
iCount = 0
For Each oResult In oResults
iCount = iCount + 1
Component.Color(FullOccurrenceName(oResult.OccurrenceOne)) = "Yellow"
Component.Color(FullOccurrenceName(oResult.OccurrenceTwo)) = "Magenta"
MessageBox.Show("     " & FullOccurrenceName(oResult.OccurrenceOne) & "      (colored yellow)" _
& vbLf & "interferes with " _
& vbLf & "     " & FullOccurrenceName(oResult.OccurrenceTwo) & "      (colored magenta)" _
& vbLf & "" _
& vbLf & "Volume: " & Round(oResult.Volume,5) & " cm^3", _
" Interference "& iCount)
Component.Color(FullOccurrenceName(oResult.OccurrenceOne)) = "As Material"
Component.Color(FullOccurrenceName(oResult.OccurrenceTwo)) = "As Material"
Next
End Sub
' Used to display the full path of an occurrence. This is the path of the
' occurrence within the assembly structure.
Private Function FullOccurrenceName(Occ As ComponentOccurrence) As String
Dim i As Integer
For i = 1 To Occ.OccurrencePath.Count
FullOccurrenceName = Occ.OccurrencePath.Item(i).Name
Next
End Function
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
