help export step file to iam
leoa.87
Message 1 of 34
leoa.87
hello, I need some help ...
i have an assembly file with ilogic rules and part and subassemblies.
according to certain ilogic rules I need to export only the visible elements and not all the parts present in the assembly to file step.
I found a rule already made and it works but not as I would like.
the problem is this rule exports the visible files but also the derivatives which, however, are not visible in the assembly.
how could I do not to make it exhibit a derivative part.
the derived part is used for a mirrored part so in my assembly it is not visually present.
I can't delete the link with the derived part because it's all parametric and I need the parameters
the rule I am using is this:
Sub Main()
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
End If
'get user input
' If MessageBox.Show ( _
' "This will create a STP file for all of the asembly components that have drawings files." _
' & vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
' & vbLf & " " _
' & vbLf & "Are you sure you want to create STP Drawings for all of the assembly components?" _
' & vbLf & "This could take a while.", "iLogic - Batch Output STPs ",MessageBoxButtons.YesNo) = vbNo Then
' Exit Sub
' End If
Dim STEPTranslator As TranslatorAddIn
Dim oContext As TranslationContext
Dim oOptions As NameValueMap
Dim oDataMedium As DataMedium
Call ConfigureSTEPTranslatorSettings(STEPTranslator, oContext, oOptions, oDataMedium)
'oPath = ThisDoc.Path
oFolder = "C:\Users\STEFANIA\Desktop\Nuova cartella (3)" & "\" & oAsmName & " STEP Files"
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
End If
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'
'look at the files referenced by the assembly
Dim oRefDoc As Document
For Each oRefDoc In oAsmDoc.AllReferencedDocuments
idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
' If(System.IO.File.Exists(idwPathName)) Then
Dim oSTEPDoc As Document
oSTEPDoc = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -4)
' oRevNum = oDrawDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
'oDesc = oRefDoc.iProperties.Value("Project", "Description")
oDesc = oSTEPDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
'********************For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
End If
On Error Resume Next
' 'Set the STP target file name
' If oRevNum = Nothing Then
' oDataMedium.FileName = oFolder & "\" & oFileName & ".STP"
oSTEPDoc.SaveAs(oFolder & "\" & oFileName &"_"& Parameter ("sospensione") & oDesc & (".stp") , True)
' Else
' End If
Call STEPTranslator.SaveCopyAs(oSTEPDoc, oContext, oOptions, oDataMedium)
oRefDoc.Close
On Error Goto 0
' End If
Next
'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
' Dim oAsmDrawingDoc As DrawingDocument
' oAsmDrawingDoc = ThisApplication.Documents.Open(ThisDoc.ChangeExtension(".idw"), True)
' oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -4)
' oAsmDrawingRev = oAsmDrawingDoc.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
' On Error Resume Next
' 'Set the PDF target file name
' If oAsmDrawingRev = Nothing Then
' oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & ".pdf"
' Else
' oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & " Rev." & oRevNum & ".pdf"
' End If
' Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
' oAsmDrawingDoc.Close
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
Shell("explorer.exe " & oFolder,vbNormalFocus)
End Sub
Sub ConfigureSTEPTranslatorSettings(ByRef STEPTranslator As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
' Set application protocol.
' 2 = AP 203 - Configuration Controlled Design
' 3 = AP 214 - Automotive Design
oOptions.Value("ApplicationProtocolType") = 3
' Other options...
'oOptions.Value("Author") = ""
'oOptions.Value("Authorization") = ""
'oOptions.Value("Description") = ""
'oOptions.Value("Organization") = ""
' Dim oData As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".stp"
oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oDataMedium)
End If
End Sub
Accepted solutions (3)
Replies (33)
Message 21 of 34
leoa.87
I need to provide the flat model in dwg format for laser cutting.
currently i can supply single step files from an assembly but i need dwg as flat models
Message 22 of 34
leoa.87
hi, I tried to insert the export of flat models in dxf format in the existing rule.
only, however, I also export the deleted files.
how can I align the export of only the components visible in the assembly as it happens for the export of step files?
Sub Main()
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	Exit Sub
End If
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim sAsmName As String = System.IO.Path.GetFileNameWithoutExtension(oAsmDoc.FullFileName )
Dim sFolder As String = "C:\Users\l.azzariti\Desktop\Output" & "\" & sAsmName & "_" & Parameter("RIF_CMA") & "_" & Parameter("RIF_ID") & "_" & "Step Files"
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium  = ThisApplication.TransientObjects.CreateDataMedium
If Not System.IO.Directory.Exists(sFolder) Then
	System.IO.Directory.CreateDirectory(sFolder)
End If
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
	If Not oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Continue For
	'get all occurrences of the referenced file, if one on them is visible - export that file to STEP, otherwise skip
	Dim oOccs As ComponentOccurrencesEnumerator = oAsmDoc.ComponentDefinition.Occurrences.AllReferencedOccurrences(oRefDoc)
	Dim oOcc As ComponentOccurrence
	Dim bVis As Boolean = False
	For Each oOcc In oOccs
		If oOcc.Visible
			bVis = True
			Exit For
		End If
	Next
	If bVis = False Then
		Continue For 'Next For
	End If
	If(System.IO.File.Exists(oRefDoc.FullDocumentName)) Then
		Dim sFilename As String = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.FullDocumentName)
		Dim sDesc As String = oRefDoc.PropertySets.Item("Design Tracking Properties").Item("Description").Value
		Parameter.Quiet = True
		Dim sRIF_CMA As String = Parameter("RIF_CMA")
		Dim sRIF_ID As String = Parameter("RIF_ID")
		oDataMedium.FileName = sFolder & "\" & sFilename & "_" & sRIF_CMA & "_" & sRIF_ID & sDesc & ".stp"
		Try
			Call STEPTranslator.SaveCopyAs(oRefDoc, oContext, oOptions, oDataMedium)
		Catch
			MsgBox("Export of " & oRefDoc.DisplayName & " failed. Continue next one", MsgBoxStyle.Critical)
		End Try
	End If
Next
Try
'Set the DXF target file name
Try
CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR")
Catch
CustomName ="XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert
End Try
		oDataMedium.FileName = sFolder & "\" & sFilename & "_" & sRIF_CMA & "_" & sRIF_ID & sDesc & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
End If
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
'just for check its works coretcly
'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
'MessageBox.Show(i,"title",MessageBoxButtons.OK)
'If i=2 Then
'Exit Sub
'End If
oCompDef.FlatPattern.ExitEdit
Catch
End Try
oDrawDoc.Close
Else
End If
Next
MessageBox.Show("File Step creati nella cartella: " & vbLf & sFolder, "iLogic")
Shell("explorer.exe " & sFolder,vbNormalFocus)
End Sub
Sub ConfigureSTEPTranslatorSettings(ByRef oSTEPTranslator As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
		' Other options...
		'oDataMedium.FileName = ThisDoc.PathAndFileName(False) & ".stp"
	End If
End Sub
Message 23 of 34
Ralf_Krieg
Hello
First, try to use the correct nomenclatur. I assume flat file means flat pattern of a sheet metal part. Or is a flat file the drawing (IDW)? And did deleted files means invisible or suppressed files? A deleted file in an assembly is deleted and also no longer exist in API structure. It can't be exported, cause it isn't there anymore.
Second, don't try to integrate all code in one sub. You'll get lost in codelines without structure. A minimum structured rule would be like
Sub Main
    Call of PDF export sub
    Call of DXF export sub
End Sub
Sub PDF Export
   code to export PDF
End sub
Sub DXF Export
   code to exportDXF
End Sub
You'll see, for example, that you are able to expand and collapse the complete code of a sub with one mouse click.This will make your code much more easier to read, reproduce and understand. For yourself and all others.
In your Sub Main you traverse through the AllReferencedFiles collection and get all Parts. For every Part you get all Occurrences. If one of the occurrences is visible, you export it to STEP. At this point you have the part you want to export the drawing "in your hands". Start right here to check for an existing drawing file and if it exists, open and export it as DXF. It is not necessary to repeat the search for part files.
Your code seems to be a sum a more than one copy and paste action. For instance, a DrawingDocument.ComponentDefinition did not exist. This will never work. If you please answer my introducing questions, we can modify your code to a working version.
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 24 of 34
leoa.87
hello and thanks for your reply.
..you have highlighted my errors which are mainly the result of the translation and also that up to 6 months ago I did not know ilogic.
to clarify I'm working on an assembly iam file.
this contains other sub-assemblies which on the basis of rules are suppressed so as to export in step files only the visible elements (not suppressed) obviously in the customized level of detail.
now I would like to add also the export of flat patterns in dxf of the single ipt files present in my assembly.
therefore the logic of the rule must always be the same so do not expose the suppressed models but only those active and visible at that moment.
for example my problem was also related to the mirror files, it must not export a source ipt file which in the assembly has been deleted but only the active mirror file.
hope you can help me
Message 25 of 34
Ralf_Krieg
Hello
Thanks for your explanations. Helped me to understand what you want to do. I've added dxf export of flat pattern. Could not test it now. If errors occur, post it here. 🙂
Sub Main()
		Exit Sub
	End If
	End If
			If oOcc.Visible
				bVis = True
				Exit For
			End If
		Next
		End If
			Try
			Catch
			End Try
			Try
				Call ExportDXF(oRefDoc, sFolder, sFilename, sRIF_CMA, sRIF_ID, sDesc)
			Catch
			End Try
		End If
	Next
End Sub
Sub ExportDXF(ByVal oDoc As PartDocument, ByVal sFolder As String, ByVal sFilename As String, ByVal sRIF_CMA As String, ByVal sRIF_ID As String, ByVal sDesc As String)
	' Exit if not a sheet metal document
	If Not oDoc.DocumentSubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Exit Sub
	Try
	Catch
	End Try
	Dim sFullFilename As String = sFolder & "\" & sFilename & "_" & sRIF_CMA & "_" & sRIF_ID & sDesc & ".dxf"
	oCompDef = oDoc.ComponentDefinition
		oCompDef.Unfold
	Else
	End If
	Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
	oCompDef.DataIO.WriteDataToFile( sOut, sFullFilename)
End Sub
		' Other options...
	End If
End Sub
R. Krieg
RKW Solutions
Message 26 of 34
leoa.87
hi i tried the code.
however it generates an error in dxf export.
"failed. Continue next one"
in the end it exports only the step files but fails to export the dxf.
it does not generate error codes but only this message.
Message 27 of 34
Ralf_Krieg
Hello
There is a little mistake I made. Can you please edit the line
into
If Not oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Exit Sub
R. Krieg
RKW Solutions
Message 28 of 34
leoa.87
I entered the change but it gives me the same error.
I tried to insert a msgbox before the ExportDXF call and the message "test" appears but the same message after the ExportDXF call does not appear.
it seems to me that it cannot call Export DXF
Message 29 of 34
Ralf_Krieg
Hello
I tried it with a little assembly with one sheetmetal part. This runs fine. Can you upload a demo assembly with one part where the error occurs?
You can also edit the catch part to get the exception message
Try
Catch ex As Exception
    'MsgBox("Export of " & oRefDoc.DisplayName & " failed. Continue next one", MsgBoxStyle.Critical)
    MsgBox(ex.message)
End Try
R. Krieg
RKW Solutions
Message 30 of 34
leoa.87
I understand the problem ...
it appears that the assembly ipt files must be opened in order to be exported.
starting from the assembly, if the ipt files are not opened, the export of the dxf files is blocked.
it would be necessary to insert in the code the possibility to open the ipt files and then maybe close them automatically once the export is done.
Message 31 of 34
Ralf_Krieg
Hello
Yes and No. The part file is already opened. Otherwise you could not see it in your assembly. My mistake (sorry) was, to enter the flat pattern environment for export, the part must be the active edit document. This can either be done in line edit in assembly or open the part in an separate view. Let's try the separate view. In addition we deactivate the updating of screen, so you want so anything of creating new view and clos again.
Replace the lines:
Try
    MsgBox(ex.message)
End Try
 with:
ThisApplication.ScreenUpdating = False
			Dim oView As Inventor.View = oRefDoc.Views.Add()
			Try
				MsgBox(ex.Message)
			Finally
				oView.Close
				ThisApplication.ScreenUpdating = True
			End Try
R. Krieg
RKW Solutions
Message 32 of 34
leoa.87
...almost...
the export of the dxf is performed but the dxf is not flat patterns but a kind of projection of the folded model
Message 33 of 34
Ralf_Krieg
Hello
Is there a flat pattern in the the part document and is it correct or is it not unfolded due to any error? I can not reproduce this with my testfile.
R. Krieg
RKW Solutions
Message 34 of 34
leoa.87
you are right...
it had lost its sheet thickness.
I corrected the sheet metal parameters and everything works.
Thanks 1000: D
