12:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I had a macro that exported dxf's of all the sheet metal parts in an assembly marked with the Vendor or the Category as "Laser" and I have an edited version of the Ilogic found on https://clintbrown.co.uk/2018/10/07/automatic-drawings-with-ilogic/ so it works in 2018. I was trying to make the macro run the Ilogic on all the correct parts but can only get it to partially work.
The "RuleForDrawing" Ilogic is the one that is set to run after open instead of the "Create Drawing" like in the link.
