Hi @byzkc54. That error message does not give us any useful information. What is "Kaydetme Formu"? It looks like there is a Windows Form showing just behind that error message in your image. Was that created by an iLogic rule, Inventor add-in, VBA UserForm, external exe program, or what? If you have access to the source code that created that form, can you post that code here, so we can attempt to debug the code?
Edit: Also, can you translate some of the words to English, so we can understand what it is saying in certain places? If words are in an image, we can not select them to attempt to translate them to our own language, but if you paste text, we may be able to.
Wesley Crihfield
(Not an Autodesk Employee)
Imports System.Windows.Forms
Imports System.Drawing
Imports System
Imports System.Math
Imports System.Collections
Imports Microsoft.VisualBasic
Imports Autodesk.iLogic.Interfaces
Imports Autodesk.iLogic.Runtime
AddReference "System.Drawing.dll"
Public Sub Main()
Dim form As New System.Windows.Forms.Form()
form.Text = "Kaydetme Formu"
Dim comboBox1 As New System.Windows.Forms.ComboBox()
comboBox1.Items.Add("01")
comboBox1.Items.Add("02")
comboBox1.Location = New System.Drawing.Point(10, 10)
form.Controls.Add(comboBox1)
Dim comboBox2 As New System.Windows.Forms.ComboBox()
comboBox2.Items.Add("A")
comboBox2.Items.Add("B")
comboBox2.Location = New System.Drawing.Point(10, 40)
form.Controls.Add(comboBox2)
Dim saveButton As New System.Windows.Forms.Button()
saveButton.Text = "Kaydet"
saveButton.Location = New System.Drawing.Point(10, 70)
AddHandler saveButton.Click, AddressOf SaveButton_Click
form.Controls.Add(saveButton)
System.Windows.Forms.Application.Run(form)
End Sub
Sub SaveButton_Click(sender As Object, e As EventArgs)
Dim comboBox1 As System.Windows.Forms.ComboBox = CType(sender, System.Windows.Forms.Button).Parent.Controls(0)
Dim comboBox2 As System.Windows.Forms.ComboBox = CType(sender, System.Windows.Forms.Button).Parent.Controls(1)
Dim comboBox1Value As String = comboBox1.SelectedItem.ToString()
Dim comboBox2Value As String = comboBox2.SelectedItem.ToString()
Dim doc As Inventor.Document = ThisApplication.ActiveDocument
doc.PropertySets.Item("Design Tracking Properties").Item("Custom").Value("Name") = comboBox1Value
doc.PropertySets.Item("Design Tracking Properties").Item("Custom").Value("Value") = comboBox2Value
End Sub
Hi @byzkc54 . I modified your code a bit and it started working. Changes in lines 43-49.
Imports System
Imports System.Math
Public Sub Main()
End Sub
Dim oInvApp As Inventor.Application = ThisApplication
Dim oDoc As Inventor.Document = oInvApp.ActiveDocument
Dim oCustom As PropertySet = oDoc.PropertySets("Inventor User Defined Properties")
Try : oCustom("Name").Value = comboBox1Value
Catch : oCustom.Add(comboBox1Value, "Name") : End Try
Try : oCustom("Value").Value = comboBox2Value
Catch : oCustom.Add(comboBox2Value, "Value") : End Try
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
