Glitch when using SketchLines.AddByTwoPoints
I snapped up some code for drawing lines in Sketch.
Here's the line I am referencing.
oSketch.SketchLines.AddByTwoPoints(oTransGeom.CreatePoint2d(0, 0), oTransGeom.CreatePoint2d(4, 0))
The glitch is, the coordinates of the points measure metric.
The line measures 1.5748031 in.
I expected it to measure 4 in.
My file is set to inches units.
What am I missing here?
frederic.vandenplas
While programming, linear dimensions are always in cm, degrees in radians, so you need to multiply 4 with 2.54. as a metric man, i'm happy with that 😃
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
bshbsh
i was always wondering why they chose cm instead of a proper SI prefix. just to add another unnecessary conversion. all technical people i know of use mm. i would deffo be more happy with that. cm is only used by tailors and carpenters Smiley Very Happy
