Changing default settings
Is it possible to change the default settings for when you select a polygon during sketching? Currently it defaults to 6 sides. I would like mine to default to 3. I am guessing somewhere in the code there would be a setting for this or a way of changing it?
frederic.vandenplas
No it's not possible by default settings Smiley Sad
I managed to do it for creating a custom detail view with specific settings by using sendkeys (TAB/TAB/...)
This was written in .NET
Private Sub CustomDetailView_OnExecute(Context As NameValueMap) Handles CustomDetailView.OnExecute
            Try
                Dim oDrawDoc As DrawingDocument = InvApp.ActiveDocument
                Dim oDrawingView As DrawingView
                If oDrawDoc.ActiveSheet.DrawingViews.Count > 1 Then
                    oDrawingView = InvApp.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select view.")
                Else
                    oDrawingView = oDrawDoc.ActiveSheet.DrawingViews.Item(1)
                oDrawDoc.SelectSet.Select(oDrawingView)
                Dim oCommandMgr As CommandManager = InvApp.CommandManager
                Dim oControlDef As ControlDefinition = oCommandMgr.ControlDefinitions("DrawingDetailViewCmd")
                Call oControlDef.Execute()
                SendKeys.SendWait("{TAB}")
                SendKeys.SendWait(My.Settings.ActualScale)
                SendKeys.SendWait("+{TAB}")
                SendKeys.SendWait("{RIGHT}")
            Catch ex As Exception
                MsgBox(Err.Description & " " & Err.Number)
            End Try
        End Sub
 So i've tried it for the polygon function too and this is the code in vba, you need to create a button on the ribbon, otherwise you will end with the sended key in your code 🙂
Sub CustomPolygon()
                Set oCommandMgr = ThisApplication.CommandManager
                Set oControlDef = oCommandMgr.ControlDefinitions("SketchPolygonCmd")
                SendKeys "{3}"
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
