Getting property Comments from a virtual part
goran_nilssonK2TWB
goran_nilssonK2TWB
Hello!
I'm going to export properties from my assembly model to an Excel sheet.
Most everything works well but I can't get access to property Comments at virtual parts in my assembly
My code is:
If TypeOf bRow.ComponentDefinitions(1) Is VirtualComponentDefinition Then
	xlWorksheet.Range("B" & row).Value = bRow.ComponentDefinitions(1).PropertySets("Design Tracking Properties")("Description").Value
	xlWorksheet.Range("C" & row).Value = bRow.ComponentDefinitions(1).PropertySets("Design Tracking Properties")("Part Number").Value
    xlWorksheet.Range("D" & row).Value = bRow.ComponentDefinitions(1).PropertySets("Inventor Document Summary Information")("Comments").Value
 What's the problem? Isn't possible to access property Comments at virtual components?
/Göran
Andrii_Humeniuk
Hi @goran_nilssonK2TWB . I found a bug in your code. You have incorrectly defined PropertySets in line 4, instead of "Inventor Document Summary Information" you should write "Inventor Summary Information".
	xlWorksheet.Range("B" & Row).Value = bRow.ComponentDefinitions(1).PropertySets("Design Tracking Properties")("Description").Value
	xlWorksheet.Range("C" & Row).Value = bRow.ComponentDefinitions(1).PropertySets("Design Tracking Properties")("Part Number").Value
    xlWorksheet.Range("D" & Row).Value = bRow.ComponentDefinitions(1).PropertySets("Inventor Summary Information")("Comments").Value
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
goran_nilssonK2TWB
@Andrii_Humeniuk Thank you!
I thought I had tried it but apperantly not!
