Getting hole tolerance by Inventor API using c++
I'm trying to get hole tolerance by Inventor API using c++ but the value returned is not correct.
the code is:
Parameter* diam = m_Feature->GetHoleDiameter(); // m_Feature is a given HoleFeature
double tol = diam->Tolerance; // returned 1.0
BSTR str = diam->Tolerance->HoleTolerance; // returned "0".
// The correct value is 2.89
How can I get the correct tolerance value?
Naor.
whunter
Hi Naor --
Wrong forum, I think you'll have more luck here:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
