For some reason when I try to export all my PDF's to a certain location I get an error (it worked yesterday)
Imports System.IO
Sub Main()
Dim m_inventorApp As Inventor.Application = ThisApplication
Dim oDWGAddIn As TranslatorAddIn = Nothing
Dim i As Long
For i = 1 To m_inventorApp.ApplicationAddIns.Count
If m_inventorApp.ApplicationAddIns.Item(i).ClassIdString ="{C24E3AC2-122E-11D5-8E91-0010B541CD80}" Then
oDWGAddIn = m_inventorApp.ApplicationAddIns.Item(i)
Exit For
Next
If oDWGAddIn Is Nothing Then
MsgBox("DWG add-in not found.")
Exit Sub
If Not oDWGAddIn.Activated Then
oDWGAddIn.Activate()
Dim doc As Document = ThisDoc.Document
Dim oFilePath As String = ThisDoc.Path
Dim oProjectNumber As String = Mid(oFilePath, 39, 5)
oExportFolder = "C:\Exports\03 - PDF Exports" & oProjectNumber & "\"
If System.IO.Directory.Exists(oExportFolder) = False Then
System.IO.Directory.CreateDirectory(oExportFolder)
ElseIf System.IO.Directory.Exists(oExportFolder) = True Then
'What to do with it if it does exist here.
' Dim oExportPath As String = System.IO.Path.GetDirectoryName(doc.FullFileName) & "\ACAD"
' If Not System.IO.Directory.Exists(oExportPath) Then: System.IO.Directory.CreateDirectory(oExportPath): End If
Dim DrawList As New ArrayList
If doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
'MainDoc(oExportPath)
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, DrawList, oExportPath)
Else
'Drawing/Presentation/Unknown = End script + message
i = MessageBox.Show("Huidige document is geen assembly", "Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
m1 = MsgBox("Batchplot DWG complete", MessageBoxButtons.YesNo + MessageBoxIcon.Question, "Information")
If m1 = vbYes Then
Dim Proc As String = "Explorer.exe"
Dim Args As String = ControlChars.Quote & oExportFolder & ControlChars.Quote
Process.Start(Proc, Args)
End Sub
Sub MainDoc(oExportPath As String)
IDWName = ThisDoc.ChangeExtension(".idw")
DWGName = ThisDoc.ChangeExtension(".dwg")
FindDrawing(DWGName, IDWName, oExportFolder)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, DrawList As ArrayList, oExportFolder As String)
Dim oOcc As ComponentOccurrence
For Each oOcc In Occurrences
If oOcc.Suppressed = False Then
If Not oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
strName = oOcc.Definition.Document.FullDocumentName
If DrawList.Contains(strName) = False Then
IDWName = Left(strName, Len(strName) - 4) & ".idw"
DWGName = Left(strName, Len(strName) - 4) & ".dwg"
DrawList.Add(strName)
If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
TraverseAssembly(oOcc.SubOccurrences, Level + 1, DrawList, oExportFolder)
Next
End Sub
Sub FindDrawing(DWGName As String, IDWName As String, oExportFolder As String)
If System.IO.File.Exists(DWGName) Then
Printdwg(DWGName, oExportFolder)
ElseIf System.IO.File.Exists(IDWName) Then
Printdwg(IDWName, oExportFolder)
'ThisApplication.Documents.Open(DWGName, True)
End Sub
Sub Printdwg(oDocName As String, oExportFolder As String)
Dim oDoc As Document
Dim oApp As Inventor.Application = ThisApplication
oDoc = oApp.Documents.Open(oDocName, True)
oDoc.Activate
Try
Dim oNameValueMap As NameValueMap = m_inventorApp.TransientObjects.CreateNameValueMap
Dim strIniFile As String = "C:\$WorkingFolder\Settings\Inventor\Design Data\DWG-DXF\exportdwg.ini"
Call oNameValueMap.Add("Export_Acad_IniFile", strIniFile)
Dim oContext As TranslationContext
oContext = m_inventorApp.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
Dim oOutputFile As DataMedium = m_inventorApp.TransientObjects.CreateDataMedium
oPath = oExportPath
oFileName = Right(oDocName, Len(oDocName) - InStrRev(oDocName, "\", -1))
oFileName = Left(oFileName, Len(oFileName) - 4)
Dim oPropSet As PropertySet = oDoc.PropertySets.Item("Inventor Summary Information")
Dim oProp As Inventor.Property = oPropSet.Item("Revision Number")
oRevNum = oProp.Value
If oRevNum = "" Then
oRevtxt = ""
Else
oRevtxt = "-"
'MsgBox(oExportPath & "\" & oFileName & oRevtxt & oRevNum & ".dwg")
oOutputFile.FileName = oExportFolder & "\" & oFileName & oRevtxt & oRevNum & ".dwg"
Dim oDWGAddIn As TranslatorAddIn = m_inventorApp.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
Call oDWGAddIn.SaveCopyAs(m_inventorApp.ActiveDocument, oContext, oNameValueMap, oOutputFile)
Catch
i = MessageBox.Show("Unable to export drawing" & vbLf & oPath, "Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
Finally
oDoc.Close(True)
End Try
'oDoc.Close
End Sub
Can someone help/explain me? The error on 135-139 starts.
Ciao
