Getting an error while export PDF
GKR2023
GKR2023
For some reason when I try to export all my PDF's to a certain location I get an error (it worked yesterday)
Imports System.IO
Sub Main()
	Dim m_inventorApp As Inventor.Application = ThisApplication
	Dim oDWGAddIn As TranslatorAddIn = Nothing
	Dim i As Long
	For i = 1 To m_inventorApp.ApplicationAddIns.Count
		If m_inventorApp.ApplicationAddIns.Item(i).ClassIdString ="{C24E3AC2-122E-11D5-8E91-0010B541CD80}" Then
			oDWGAddIn = m_inventorApp.ApplicationAddIns.Item(i)
			Exit For
		End If
	Next
	If oDWGAddIn Is Nothing Then
		MsgBox("DWG add-in not found.")
		Exit Sub
	End If
	If Not oDWGAddIn.Activated Then
		oDWGAddIn.Activate()
	End If
	Dim doc As Document = ThisDoc.Document
	Dim oFilePath As String = ThisDoc.Path
	Dim oProjectNumber As String = Mid(oFilePath, 39, 5)
	oExportFolder = "C:\Exports\03 - PDF Exports" & oProjectNumber & "\"
	If System.IO.Directory.Exists(oExportFolder) = False Then
	System.IO.Directory.CreateDirectory(oExportFolder)
ElseIf System.IO.Directory.Exists(oExportFolder) = True Then
	'What to do with it if it does exist here.
End If
'	Dim oExportPath As String = System.IO.Path.GetDirectoryName(doc.FullFileName) & "\ACAD"
'	If Not System.IO.Directory.Exists(oExportPath) Then: System.IO.Directory.CreateDirectory(oExportPath): End If
	Dim DrawList As New ArrayList
	If doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		'MainDoc(oExportPath)
		Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
		TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, DrawList, oExportPath)
	Else
	'Drawing/Presentation/Unknown = End script + message
		i = MessageBox.Show("Huidige document is geen assembly", "Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	End If
	m1 = MsgBox("Batchplot DWG complete", MessageBoxButtons.YesNo + MessageBoxIcon.Question, "Information")
		If m1 = vbYes Then
			Dim Proc As String = "Explorer.exe"
			Dim Args As String = ControlChars.Quote & oExportFolder & ControlChars.Quote
			Process.Start(Proc, Args)
		End If
End Sub
Sub MainDoc(oExportPath As String)
	IDWName = ThisDoc.ChangeExtension(".idw")
	DWGName = ThisDoc.ChangeExtension(".dwg")
	FindDrawing(DWGName, IDWName, oExportFolder)
End Sub
Private Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer, DrawList As ArrayList, oExportFolder As String)
	Dim oOcc As ComponentOccurrence
	For Each oOcc In Occurrences
		If oOcc.Suppressed = False Then
			If Not oOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
				strName = oOcc.Definition.Document.FullDocumentName
				If DrawList.Contains(strName) = False Then
					IDWName = Left(strName, Len(strName) - 4) & ".idw"
					DWGName = Left(strName, Len(strName) - 4) & ".dwg"
					DrawList.Add(strName)
				End If
				If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
					TraverseAssembly(oOcc.SubOccurrences, Level + 1, DrawList, oExportFolder)
				End If
			End If
		End If
	Next
End Sub
Sub FindDrawing(DWGName As String, IDWName As String, oExportFolder As String)
	If System.IO.File.Exists(DWGName) Then
		Printdwg(DWGName, oExportFolder)
	ElseIf System.IO.File.Exists(IDWName) Then
		Printdwg(IDWName, oExportFolder)
		'ThisApplication.Documents.Open(DWGName, True)
	End If
End Sub
Sub Printdwg(oDocName As String, oExportFolder As String)
	Dim oDoc As Document
	Dim oApp As Inventor.Application = ThisApplication
	oDoc = oApp.Documents.Open(oDocName, True)
	oDoc.Activate
	Try
		Dim oNameValueMap As NameValueMap = m_inventorApp.TransientObjects.CreateNameValueMap
		Dim strIniFile As String = "C:\$WorkingFolder\Settings\Inventor\Design Data\DWG-DXF\exportdwg.ini"
		Call oNameValueMap.Add("Export_Acad_IniFile", strIniFile)
		Dim oContext As TranslationContext
		oContext = m_inventorApp.TransientObjects.CreateTranslationContext
		oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
		Dim oOutputFile As DataMedium = m_inventorApp.TransientObjects.CreateDataMedium
		oPath = oExportPath
		oFileName = Right(oDocName, Len(oDocName) - InStrRev(oDocName, "\", -1))
		oFileName = Left(oFileName, Len(oFileName) - 4)
		Dim oPropSet As PropertySet = oDoc.PropertySets.Item("Inventor Summary Information")
		Dim oProp As Inventor.Property = oPropSet.Item("Revision Number")
		oRevNum = oProp.Value
		If oRevNum = "" Then
			oRevtxt = ""
		Else
			oRevtxt = "-"
		End If
		'MsgBox(oExportPath & "\" & oFileName & oRevtxt & oRevNum & ".dwg")
		oOutputFile.FileName = oExportFolder & "\" & oFileName & oRevtxt & oRevNum & ".dwg"
		Dim oDWGAddIn As TranslatorAddIn = m_inventorApp.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
		Call oDWGAddIn.SaveCopyAs(m_inventorApp.ActiveDocument,	oContext, oNameValueMap, oOutputFile)
	Catch
	i = MessageBox.Show("Unable to export drawing" & vbLf &  oPath, "Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
	Finally
		oDoc.Close(True)
	End Try
	'oDoc.Close
End Sub
Can someone help/explain me? The error on 135-139 starts.
Ciao
WCrihfield
Hi @GKR2023.  I see 2 different places that might need to be fixed, but not sure.  Within your TraverseAssembly Sub routine, is the following line of code:
That should probably end with FullFileName, instead of FullDocumentName.  They will often contain the same value, but any time an iPart, iAssembly, or document with multiple ModelStates is encountered, the FullDocumentName will usually contain more information after the FullFileName portion, such as the iPart member name, iAssembly member name, or ModelState member name, within "<" & ">" characters.  The way your code handles separating the different parts of file names out, that could definitely cause problems.  The other line of code that looks wrong to me is the following line, within the Printdwg Sub routine:
oPath = oExportPath
The second variable being supplied to that Sub routine is "oExportFolder", not oExportPath, and the oExportPath variable is not declared or a value set to it anywhere within that Sub routine before it reaches that line.  Then the lines of code you mentioned getting error feedback from uses that oPath variable.  Just my initial thoughts from a quick read through of your overall code.
Edit:  Another thing that might stump up your TraverseAssembly routine is if it encountered a 'virtual' component.  Those would not have a Document to access its FullFileName or FullDocumentName from.  You can filter them out by checking:
If TypeOf oOcc.Definition Is VirtualComponentDefinition Then Continue For
but only after you have checked that the component is not suppressed, because accessing the Definition of a suppressed component results in an error.
Wesley Crihfield
(Not an Autodesk Employee)
alexanderboogaard
This updated code seems to work. The issue was indeed with oExportPath.
Imports System.IO
Sub Main()
Break
	Dim i As Long
			Exit For
		End If
	Next
		Exit Sub
	End If
	End If
End If
		MainDoc(oExportFolder)
		TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, DrawList, oExportFolder)
	Else
	End If
		If m1 = vbYes Then
		End If
End Sub
Sub MainDoc(oExportFolder As String)
End Sub
				End If
				End If
			End If
		End If
	Next
End Sub
	End If
End Sub
	oDoc.Activate
	Try
		oPath = oExportPath
			oRevtxt = ""
		Else
			oRevtxt = "-"
		End If
	Catch
	Finally
		oDoc.Close(True)
	End Try
	'oDoc.Close
End Sub
Kind regards,
Alexander Boogaard
GKR2023
Thanks this worked :)!
Ciao
