GetObject. need Help
Try this again. CreateObject!!
Need help from VB Guru. I am trying to create the Inventor.Application object. I get an error that says
"ActiveX component can't create object" I have the reference set to the Autodesk Inventor library. Here is the test sample code that fails:
Dim oApp As Inventor.Application
On Error Resume Next
Set oApp = GetObject(, "Inventor.Application")
   If Err Then
        retval = MsgBox("Inventor Must be Running. Would You Like to Start Inventor?", vbQuestion + vbYesNo, "Start Inventor")
        If retval = 6 Then
            Set oApp = Nothing
            Set oApp = CreateObject("Inventor.Application")
            If Err Then
                End
        Else
            End
The GetObject works if Inventor is running. Can't figure out why CreateObject fails.
Thanks for any help.
Ray C.
After Create add
oApp.Visible = True
PS Bet if you look in Task Manager you have a instance or two of Inventor running now.
8^)
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"srayc" wrote in message news:f18140d.-1@WebX.maYIadrTaRb...
error that says
Forgot to mention, you also need to put a err.clear before the Create object. The error
you are seeing is the one that was thrown from the GetObject Function.
Kent
Assistant Moderator
Thanks Kent, I knew it had to be something silly I was doing or not doing. Works great now.
Thanks again
Ray C.
