GetObject. need Help
09:31 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Try this again. CreateObject!!
Need help from VB Guru. I am trying to create the Inventor.Application object. I get an error that says
"ActiveX component can't create object" I have the reference set to the Autodesk Inventor library. Here is the test sample code that fails:
Dim oApp As Inventor.Application
On Error Resume Next
Set oApp = GetObject(, "Inventor.Application")
If Err Then
retval = MsgBox("Inventor Must be Running. Would You Like to Start Inventor?", vbQuestion + vbYesNo, "Start Inventor")
If retval = 6 Then
Set oApp = Nothing
Set oApp = CreateObject("Inventor.Application")
If Err Then
End
End If
Else
End
End If
End If
If Err Then
If retval = 6 Then
Set oApp = Nothing
If Err Then
End
End If
Else
End
End If
End If
The GetObject works if Inventor is running. Can't figure out why CreateObject fails.
Thanks for any help.
Ray C.
