GetActiveDocument
GetActiveDocument
Ruffy85
GetActiveDocument
Ruffy85
Hello together,
i try to convert this ilogic to C#
 'catch and skip errors
On Error Resume Next
'define the active assembly
Dim oAssyDoc As AssemblyDocument
oAssyDoc = ThisApplication.ActiveDocument
'get user input as True or False
wfBoolean = InputRadioBox("Turn all Sketches On/Off", "On", "Off", False, "iLogic")
' Process the rule, wrapping it in a transaction so the
' entire process can be undone with a single undo operation.
Dim trans As Transaction
trans = ThisApplication.TransactionManager.StartTransaction( _
        oAssyDoc, "Sketches Off")
'Check all referenced docs
Dim oDoc As Inventor.Document
For Each oDoc In oAssyDoc.AllReferencedDocuments
    'set Sketch visibility
    For Each oSketch In oDoc.ComponentDefinition.Sketches
    oSketch.Visible = wfBoolean
    Next
Next
'end transaction for single undo
trans.End
'upate the files
InventorVb.DocumentUpdate()
The Problem is to get access to the activedocument compdefinitionobject.
in ilogic they know inventor.Document. But in C# its not possible to access trough Inventor.Document object.
public void HideSketches()
            bool result = false;
            if (result == true)
                Inventor.Transaction oTrans = myCad.InvApp.TransactionManager.StartTransaction(myCad.InvApp.ActiveDocument, "Sketches off");
                foreach (Inventor.Document oDoc in myCad.InvApp.ActiveDocument.AllReferencedDocuments)
                    foreach (Inventor.Sketch oSketch in oDoc.ComponentDefinition.Sketches)
                        oSketch.Visible = result;
                oTrans.End();
                oDoc.Update();
i used a bool for testing, later i will implement the dialog. The Problem here is, the linepart oDoc.componentDefinition is not possible.
i have the same problem in a lot of codesnippets. where the actual DocType is not clear while programming.
Please help.
THanks
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Can you please elaborate on this:
"But in C# its not possible to access trough Inventor.Document object."
What exactly can you not access through the Inventor.Document object in C#?
I would like to help but need a clearer understanding of the problem.  Thanks.
MechMachineMan
Okay?
So do a test on the Inventor.Document to see what it's proper type is, and cast the object to a properly typed variable.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
I agree that portion of the SDK seems a bit peculiar since the various XXXDocument types are not actually derived from Document.  However, I have proceeded with code like this to deal with that in C# and it has worked for me...
   invDoc = invApp.ActiveDocument;
   if (invDoc != null && invDoc.DocumentType == DocumentTypeEnum.kPartDocumentObject)
      fileTextBox.Text = invDoc.FullFileName;
      PartDocument partDoc = invDoc as PartDocument;
      if (partDoc != null)
         PartComponentDefinition partComponentDefinition = partDoc.ComponentDefinition;
Ruffy85
yep ok that works thanks
