Get WorkPlane used within a sketch as projected geometry
- Mute
- Permalink
- Report
The situation:
- A 2D-sketch is made.
- As reference a WorkPlane is projected into the sketch
- A DimensionConstraints.AddOffset is made between the sketch geometry and the projected Workplane geometry.
The purpose:
- The feature shall be extracted from the part. The extracted data shall even containthe constraints that were made to the predefined Workplanes.
- In other parts the Feature shall be inserted with the same dimensions related to predefined Workplanes of those other parts.
The part problem I try so solve now:
Get the DimensionConstraint that uses the projected WorkPlane and know which WorkPlane it is.
This is either hard to get or I am on the wrong track.
What I tried so far:
Dim feature As PartFeature = ThisDoc.Document.ComponentDefinition.Features.Item(1)
Dim featureProfile As Profile = feature.Definition.Profile
Dim featureSketch As Sketch = featureProfile.Parent
' APPROACH 1: Coming from the Sketch-side
For Each sketchEntity In featureSketch.SketchEntities
Dim someConstraint As Object
For Each someConstraint In SketchEntity.Constraints
Try
Logger.Info("Constraint: " & someConstraint.Type & ", " & someConstraint.Parameter.Expression)
' Is there a way to go further here to "reach" the WorkPlane?
Catch
End Try
Next
Next
' APPROACH 2: Coming from the WorkPlane-side
Dim referenceWorkPlanes = New WorkPlane() {workPlanes.Item("MyWorkplane01"), workPlanes.Item("MyWorkplane02")}
Dim workPlane As WorkPlane
For Each workPlane In referenceWorkPlanes
Logger.Info("Name of WorkPlane: " & workPlane.Name)
Dim dependent As Object
For Each dependent In workPlane.Dependents
Logger.Info("Type of dependent: " & dependent.Type)
' Continue only for SketchLine objects
If (dependent.Type <> kSketchLineObject) Then Continue For
Logger.Info("Name of sketch: " & dependent.Parent.Name)
For Each someConstraint In dependent.Constraints
Dim anchorPoint As Object
' PROBLEM: Getting the anchor points is not helpful. They are just TransientGeometry and
' ' do not have a connection to the sketch(!?)
' For Each anchorPoint In offsetDimConstraint.AnchorPoints
' Logger.Info("( " & anchorPoint.X & " / " & anchorPoint.Y & " )")
' Next
' Is there a way to go further here to "reach" the sketchEntity that is used by this constraint?
Next
Next
Next
My next idea is to tackle the problem "from both sides":
- Coming from the WorkPlane-side (= approach 2 in the example above) I collect all dependants (which are projected lines) and store them in an array (multi-dimensional: one sub-array for every WorkPlane).
- Coming from the Sketch-side (= approach 1 in the example above) I see whether any SketchEntity is in one of the arrays from step 1.
- If there is a match I can get the Constraint from the SketchEntity and get the "connection" this way.
Other approaches might be working with ReferenceKeys or Attributes.
But all this feels not Inventor-native.
There must be a better way to solve this?
