Get UnitTypeEnum from UnitsOfMeasure for "Text" and "Boolean"
I'm using the UnitsOfMeasure.GetTypeFromString() method to identify and handle different units, but it seems that the method doesn't handle "Text" or "Boolean" even though kTextUnits and kBooleanUnits are valid values of the enum. Is this expected behavior or is there something I'm doing wrong? I have resorted to handling those strings before calling the helper function but I would like to be able to simplify and use only it.
Related to this, why is UserParameter.Unit not directly accessible in C#? Calling the getter (UserParameter.get_Unit) works, but seems messy and gets flagged by my linter...
flora_fang
Hi, for the first question, UnitsOfMeasure.GetTypeFromString() couldn't work for Text or Boolean, it sounds like as design from my understanding. Here is the list of unit that support by GetTypeFromString method, hope that helps.
kDefaultDisplayLengthUnit
kCentimeterLengthUnit
kMillimeterLengthUnit
kMeterLengthUnit
kMicronLengthUnit
kInchLengthUnit
kFootLengthUnit
kYardLengthUnit
kMileLengthUnit
kNauticalMileLengthUnit
kMilLengthUnit
kDefaultDisplayMassUnit
kKilogramMassUnit
kGramMassUnit
kSlugMassUnit
kLbMassMassUnit
kOunceMassMassUnit
kDefaultDisplayTimeUnit
kSecondTimeUnit
kMinuteTimeUnit
kHourTimeUnit
kDefaultDisplayTemperatureUnit
kKelvinTemperatureUnit
kCelsiusTemperatureUnit
kFarenheitTemperatureUnit
kDefaultDisplayAngleUnit
kRadianAngleUnit
kDegreeAngleUnit
kGradAngleUnit
kSteradianAngleUnit
kUnitlessUnit
kMetersPerSecondSpeedUnit
kFeetPerSecondSpeedUnit
kMilesPerHourSpeedUnit
kAcreAreaUnit
kCircularMilAreaUnit
kLiterVolumeUnit
kGallonVolumeUnit
kQuartVolumeUnit
kPintVolumeUnit
kCupVolumeUnit
kOunceVolumeUnit
kPascalPressureUnit
kPSIPressureUnit
kKSIPressureUnit
kNewtonForceUnit
kDyneForceUnit
kLbForceUnit
kOunceForceUnit
kWattPowerUnit
kHorsePowerPowerUnit
kJouleWorkUnit
kErgWorkUnit
kCalorieWorkUnit
kBtuWorkUnit
kRpmAngularVelocityUnit
kAmpElectricalUnit
kVoltElectricalUnit
kOhmElectricalUnit
kCoulombElectricalUnit
kFaradElectricalUnit
kSiemensElectricalUnit
kmhoElectricalUnit
kWeberElectricalUnit
kMaxwellElectricalUnit
kTeslaElectricalUnit
kGammaElectricalUnit
kGaussElectricalUnit
kHenryElectricalUnit
kOerstedElectricalUnit
kHertzElectricalUnit
kCandelaLuminosityUnit
kLumenLuminosityUnit
kLuxLuminosityUnit
kMoleSubstanceUnit
Flora Fang
Flora.Fang@autodesk.com
Software Quality Assurance
Design & Manufacturing
This shouldn't be by design...
UnitsOfMeasure.GetTypeFromString documentation says: "UnitsOfMeasure.GetTypeFromString Method : Given a string defining a unit this method returns the corresponding unit from the UnitsTypeEnum constant list".
kBooleanUnits and kTextUnits are both existing values in the UnitsTypeEnum. Parameter.get_Unit (which returns a string representing the unit) can return "Text" and "Boolean" because kBooleanUnits/kTextUnits are valid UnitsSpecifier and can be passed when creating the Parameter.
So calling :
UnitsOfMeasure.GetTypeFromString( Parameter.get_Unit() )
will occasionally fail because the acceptable inputs to the helper method are a narrower subset of the UnitsTypeEnum than the possible values of the Parameter.Unit property...if that's the expected behavior it would be nice to at least have it documented somewhere.
ekinsb
I would tend to agree with you.  The current behavior isn't really by design but is more just by default.  Originally, Inventor only supported value parameters and String and Boolean parameters were added later.  We had to figure out a way to add support for these new types into the API without breaking the existing behavior.  It looks like the Units property was overlooked and wasn't updated to add support for these new types.  The good news is that it's relatively easy to workaround this, which you're already doing.
Regarding your other question about the Units property, I just looked at it and confirmed what you said.  I don't beleive this is anything that we're doing in the API definition but is something that C# is doing instead.  Visual Basic uses the same interop library and the Units property is available there.  I don't know why C# chooses to expose it as the get_Units and set_Units functions instead.  I'm guessing there's an issue with using "Units" but it doesn't seem to be a reserved keyword so I don't know why it's doing what it is.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
Brian, thanks for clearing that up. I spent a couple hours stepping through code trying to figure out why it was (inconsistently) crashing, before I figured out that those values were the problem. Are the internals of the GetTypeFromString helper method anything more than a big switch statement handling each unit case? I don't think it would be difficult or a breaking change to add handling code for "Text" and "Boolean". A small change in the backend but an improvement for API consistency.
As for point 2 - it's baffled me as well. I guess it's just something funny happening with C# Properties.
Maxim-CADman77
@flora_fang
What is the source of this list and whether it got any changes for the past 7 years?
Please vote for Inventor-Idea Text Search within Option Names
