Get the suppress status of Workplane via vb.net
Hi to all,
following problem. I have a ipt file in my assembly and try to makes some constraints. Everything ios working well, but ther are some supressed workplanes, and I don't want to use them for a automatically created constraint. Is there a way to find out the workplane supress status?
Why are they supressed? They are defined on a part feature (extrusion surface). And when I supress that feature, also the Workplane is supressed.
But I only can get the visible status. Maybe there's a way to get it about the part feature, but therefore, I have to search for the part feature, and that's also a problem. I cannot get the part feature, who is used for the workplane definition (I think, it's a problem of my knowledge :))
Please see attached a small view on the browser whrer you can see the suppressed Planes.
Best Regards
Passi
Vladimir.Ananyev
You may find useful Workplane.HealthStatus property:
Private Sub Test_IfWorkplanesSuppressed()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim odef As PartComponentDefinition
  Set odef = oDoc.ComponentDefinition
  Dim oWPs As WorkPlanes
  Set oWPs = odef.WorkPlanes
  Dim wp As WorkPlane
  Set wp = oWPs.Item(4)  ' <-- some workplane
  Select Case wp.HealthStatus
    Case HealthStatusEnum.kUpToDateHealth
      Debug.Print "Unsuppressed"
    Case HealthStatusEnum.kSuppressedHealth
      Debug.Print "Suppressed"
    End Select
End Sub
 Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
and thanks, that's what I'm searching for.
So, it's solved and thank You again.
I'm using it a little bit simplified, but the hint with the health status was the thing I needed 🙂
Best Regards
Passi
(And sorry for the late response, but the remembering email was send directly into my junk-mail folder :))
