Get the current configuration name of an I-Assembly?
How do I get the current configuration name of an I-Assembly?
I am using currentrow of the I-factory, but not getting consistent results.
Balaji_Ram
I do not see an inconsistent result in using the DefaultRow to get the current configuration.
Can you please share a non-confidential sample file to help reproduce the problem ?
Here is the VBA code that i used which worked ok.
    Dim iAsmDocument As AssemblyDocument
    Set iAsmDocument = ThisApplication.ActiveDocument
    If iAsmDocument.ComponentDefinition.IsiAssemblyFactory Then
        Dim oiAssyFactory As iAssemblyFactory
        Set oiAssyFactory = iAsmDocument.ComponentDefinition.iAssemblyFactory
        Dim oiAssyTableRow As iAssemblyTableRow
        Set oiAssyTableRow = oiAssyFactory.DefaultRow
        Debug.Print "Default Row : " & oiAssyTableRow.MemberName
   End If
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Thank you Balaji_Ram,
That is pretty much the method I am using as well.
It may be user error.
I put a in a label to display the selected membername.before they continue processing the i-assembly. With this verification in place I have not seen the problem arise again.
