Get the correct Design Status iProp Value
Raider_71
Raider_71
Hi Guys I would like to know if someone can help getting the actual value of the Design Status iProperty. There are three options and if I use the normal method I only get the index number of the listbox 1,2 or 3. Is it posible to get the text string value? Also depending on the language settings it should be language correct as well?
oApprDoc.PropertySets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(PropertiesForDesignTrackingPropertiesEnum.kDesignStatusDesignTrackingProperties).Value
Is this posible to do? ... to get the language correct string value?
Thanks!
Cheers
ekinsb
Unfortunately, this is not possible.  Inventor is storing the index of the listbox in the iProperty, which is what you're seeing.  Inventor reads this and then uses that index to set the selected value in the list box.  The contents of the list box itself is buit from reading a resource file based on the current language.  These specific strings are not available through the Inventor API.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
Raider_71
Thanks Brian,
English it will be then... 🙂
Cheers
