get the circeledgeID from Normparts in Assembly to connect/replace in VBA
k-p_heurig
k-p_heurig
Hello
i have a VBA Macro witch replaces Normparts but i can not set Lockrotation and i can not define the CirceledgesID
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oCompOccs As ComponentOccurrences
Dim oCompOcc As ComponentOccurrence
For Each oCompOcc In oAsmCompDef.Occurrences
If oCompOcc.ReferencedDocumentDescriptor.FullDocumentName = "C:\Vault\Normteile\de-DE\DIN 934 - A2\DIN 934 - M8 - A2.ipt" Then
Call oCompOcc.Replace("C:\Vault\Normteile\de-DE\DIN 934 - 10 - verzinkt\DIN 934 - M4 - 10 - verzinkt.ipt", False)
End If
Next
i also found in the Forum a Sample from (06-04-2019) for connecting Parts manually select the edges.
my question is  it possible to get the CircleedgeID automatikally? like
Dim oEdge1 As Edge
Set oEdge1 = Insertconnected CircleedgeID the OLDNormpart(DINXXX.IPT) is connected to in the Assembly
Dim oEdge2 As Edge
then put a NEWNormpart (DINYYY.IPT)in the Assembly and insertConnect  it Manually to an Circeledge.
Set oEdge2 = now get the insertConnect CircleedgeID of the NEWNormpart
and connect the CircledgeID  the OLDNormpart is connected to with the CirceledgeID the NEWNormpart is conected
Dim oInsert As InsertConstraint
Set oInsert = oAsmCompDef.Constraints.AddInsertConstraint(oEdge1, oEdge2, True, 0)
 with Lockrotation is set
and delete the OLDNormpart
if this is posible i would be very happy if some one can give me an tipp where to look or even a snipped.
thanks a lot
WCrihfield
It's a little difficult to follow what you are asking for.  It sounds like you want to be able to replace a component within an assembly, while maintaining an Insert type constraint, so that the replacement part will also be constrained the same way as the replaced part was, after the code is done.  Does that sound correct?  And to do this, you want to be able to capture the corresponding circular edge on the new component and use that to replace the circular edge reference of the old component being used in that constraint, right?  Since both components don't exist in the assembly at the same time, that will be impossible to do.  However, if you have identified the constraint object and used the available methods to isolate which of its two entities is connected to the component being replaced, before replacing the component, we will then have a chance to correct the resulting 'sick' constraint after you replace the component, as long as you have a plan to be able to identify which circular edge on the new component is the one we will need to replace the old reference in the constraint.  It is likely not going to be a simple or easy task, but may be possible, if set-up right.
Wesley Crihfield
(Not an Autodesk Employee)
k-p_heurig
sorry for answer so late
iam in vaccation and do not have always access to an computer
but thanks a lot  for looking at my problem
yes that is correct.
yes that is correct,
but i forgot to mention that i place up front one new part in the assembly.for getting the edgeID
what to you mean by ,,sick,, constraint, the constraint to the old part are ok
what i want to achive is ,,LockRotaion,, after replacing  the parts
for just replacing the parts i can use the sample snippets , but how can i insert the ,,LockRotation,, after replacing the parts
greetings
kp
Ralf_Krieg
Hello
The LockRotation is a boolean property of the insertconstraint.
oInsert.LockRotation = True
R. Krieg
RKW Solutions
www.rkw-solutions.com
k-p_heurig
hallo
i found the following ilogic sample in the forum
i tryed to translate it into VBA
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oCompDef As AssemblyComponentDefinition = oAsm.ComponentDefinition
For Each oConst As AssemblyConstraint In oCompDef.Constraints
	If oConst.Type = kInsertConstraintObject
		Dim oName As String = oConst.Name
		oConst = oConst.ConvertToInsertConstraint2(oConst.EntityOne, oConst.EntityTwo, oConst.AxesOpposed, oConst.Distance.Value, True)
		On Error Resume Next
		oConst.Name = oName
	End If
Next
here the VBA Code from the Ilogic sample
Sub nixconst()
Set oAsm = ThisApplication.ActiveDocument
Set oCompDef = oAsm.ComponentDefinition
Dim oConst As AssemblyConstraint
For Each oConst In oCompDef.Constraints
If oConst.Type Is kInsertConstraintObject Then
Dim oName As String
Set oName = oConst.Name
oConst.Name = oName
End If
Next
End Sub
unfortunately there are a few Problems
kInsertConstraintObject = wrong typ
Set oName = oConst.Name = Objekt necessary
oConst = oConst.ConvertToInsertConstraint2(oConst.EntityOne, oConst.EntityTwo, oConst.AxesOpposed, oConst.Distance.Value, True) = Objekt supports this feature Methode not (translatet from German)
all the variables are picked from the Inventor API
if somebody knows what iam doing wrong
i would be very happy if i get some help
Ralf_Krieg
Hello
I don't see the sense of the saving and restoring the name, cause it doesn't change in my tests. Anyway, converted to VBA:
Dim oName As String
    If oConst.Type = kInsertConstraintObject Then
        oName = oConst.Name
        Set oConst = oConst.ConvertToInsertConstraint2(oConst.EntityOne, oConst.EntityTwo, oConst.AxesOpposed, oConst.Distance.Value, True)
        oConst.Name = oName
     End If
Next
R. Krieg
RKW Solutions
k-p_heurig
hello
the reason for all this is:
first
we have in the content Center a Family  Welding Nut witch is corrupted
my Idea was to create a new Welding Nut familiy in the content Center
and afterwards replace the Parts from the Corrupted Family with the new one
because of that many Assemblys we have with Welding Nut
i thought it a good Idea to write a makro wich replaces the Parts
AND
Put also a ,,Lockrotation,, to the Constraint.
hopefully the replaceing of the Welding Nuts wont change the BOM and the Drawing
Solution:
find in Vault all the assemblys with a Welding Nut
for Examble DIN 929 M8 A2 , remember all the Assembly name
open them one by one  in Inventor and run the makro
with replace it with the ,,NEW,, DIN 929 M8 A2 from a different Folder
so far its working
but the Lockrotation is the Problem
i found some examples in the Inventor API Help
but there you have to manually select the circle Edges witch i wonded to avoid
my thought was after replacing the Welding Nuts
i know the new Welding Nut and with it the contraint           ,,Imate   - Einfügen: -
witch i just have to lockrotate
if you have a better Idea for solving this Problem i would be very grateful to hear it
thank you very much for the VBA version
i have
,,set =,,
put on the wrong line.
greetings karl-peter
