Get the center point of circular edge
fakeru
fakeru
So I want to create a mate constraint between a workplane and a center point of circular edge.
The edge is being picked by the user, but how can I get the center point of this edge for the constraint creation?
Like in the code below, it will not work. The oWorkPlaneProxy is defined somewhere above, so that's not a problem.
oEdge2 = g_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeCircularFilter, "Select first circular edge of second connection")
Dim Point1 As Inventor.Point = oEdge2.Geometry.Center
Dim oMate As MateConstraint
oMate = oAsmCompDef.Constraints.AddMateConstraint(oWorkPlaneProxy, Point1, 0)
Regards
Alexandru
Autodesk Inventor 2015 Certified Professional
JaneFan
Hello Alexandru,
The geometry point can't be used as the argument Entity in function AddMateConstraint().
If you need the center point of a circular edge as the input, please create a workpoint at the center point first, then use the work point at the input, like this:
oAsmCompDef.Constraints.AddMateConstraint(oWorkPointProxy, oWP, 0, kInferredPoint, kNoInference)
Or there is a simpler way:
When a circular edge is chosen as an entity input, specifying the Inferred Type to kInferredPoint can do the same thing:
oAsmCompDef.Constraints.AddMateConstraint(oWP, oEdge2, 0, kNoInference, kInferredPoint)
Jane Fan
Inventor/Fusion QA Engineer
fakeru
I was thinking about creating a workpoint, but that was a last solution because I just don't want my assembly to have workpoints which the users will not understand their use.
But the your second option is just what I needed! It's was so simple. Thanks!
