Get sheet format
Get sheet format
martinhoos
Get sheet format
martinhoos
Hi all,
i like to have a code that insert sketched symbols in the right corner of my sheet. The Goal is, i have more than one different Sheets (A4, A3...) in my IDW.
How can i get the different sheet-formats (A4, A3....), so that i can calculate the right lower corner to get the insert point.
For Each oSheet In oIDW.Sheets
		Dim Format As String
		Format = ActiveSheet.Size
		MessageBox.Show(Format, "Title")
Next
The above code only gets the format from the first side...
Who can help me?
Regards an a nice Weekend ...
Martin
GeorgK
On Error Resume Next
            Select Case oDrgDoc.ActiveSheet.Size
                Case kA4DrawingSheetSize
                Case kA3DrawingSheetSize
                Case kA2DrawingSheetSize
                Case kA1DrawingSheetSize
                Case kA0DrawingSheetSize
                Case Else    ' Andere Werte.
            End Select
dgreatice
Dim oIDW as drawingdocument
Dim osheet as sheet
Select case osheet.size
Msgbox ("A4")
Msgbox ("A3")
End select
Next
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
martinhoos
Thank you for your reply. I dont know where i have to put your code in. Pls can you change my code with yours?
Thank you very much.
Regards Martin
Dim oIDW As DrawingDocument
oIDW = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oIDW.ActiveSheet
Dim oLayers As LayersEnumerator = oSheet.Parent.StylesManager.Layers
Dim sFormatName As String
If ActiveSheet.Size = "A4" Then
sFormatName = "A4"
MessageBox.Show(sFormatName , "iLogic")
ElseIf ActiveSheet.Size = "A3" Then
sFormatName = "A3"
End If
Next
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @martinhoos,
Basically, Sheet.Size property returns DrawingSheetSizeEnum Enumerator not a string value.Try the following changes in your code.
Dim oSheet As Sheet
If oSheet.Size = kA4DrawingSheetSize Then
sFormatName = "A4"
ElseIf oSheet.Size = kA3DrawingSheetSize Then
sFormatName = "A3"
ElseIf oSheet.Size = kA2DrawingSheetSize Then
sFormatName = "A2"
ElseIf oSheet.Size = kA1DrawingSheetSize Then
sFormatName = "A1"
ElseIf oSheet.Size = kA0DrawingSheetSize Then
sFormatName = "A0"
MessageBox.Show(sFormatName , "iLogic") End If Next
Refer the following link for more details about DrawingSheetSizeEnum Enumerator
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-55595BC5-77E1-485D-861D-B1FE827EE132
Please feel free to contact if there is any queries.
If problem solved, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
martinhoos
Hi chandra.shekar.g,
thank you for your reply. I tried your code, but i get no result. May be, because we are using Inventor 2015?
If i copy this line:
to the end of your code - the window is emty.
 Regards
Martin
martinhoos
Hello chandra.shekar.g,
I placed DrawingSheetSizeEnum in front of kA4DrawingSheetSize and it runs.....
Thanks again for your support
Regards Martin
Dim oSheet As Sheet
If oSheet.Size = DrawingSheetSizeEnum.kA4DrawingSheetSize Then
sFormatName = "A4"
ElseIf oSheet.Size = DrawingSheetSizeEnum.kA3DrawingSheetSize Then
sFormatName = "A3"
ElseIf oSheet.Size = DrawingSheetSizeEnum.kA2DrawingSheetSize Then
sFormatName = "A2"
ElseIf oSheet.Size = DrawingSheetSizeEnum.kA1DrawingSheetSize Then
sFormatName = "A1"
ElseIf oSheet.Size = DrawingSheetSizeEnum.kA0DrawingSheetSize Then
sFormatName = "A0"
End If
Next
