Get selected occurrence without interaction
in a separate window I want to show some properties and information of an selected occurrence in an assembly. How can I get the selected occurence from browser or graphical window?
Is there an event that gives me the selected object? I know that there are SelectEvents from Interaction, but I'd like to do this without interaction because I want to run my window in the background. I think that Interaction is not the right way because it means an active selection for a specific command, but not to capture something from the background.
I have in mind to do this with with a timer that looks for the selected object, but I'm not sure if this is a working solution and would prefer working with some kind of event. Is there something I can use?
Andreas
Balaji_Ram
Hi Andreas,
The selected browser node can be identified using the following code snippet
BrowserPane oPane = assyDoc.BrowserPanes["Model"];
            BrowserNode oTopNode = oPane.TopNode;
            foreach (BrowserNode node in oTopNode.BrowserNodes)
                if (node.Selected)
                    MessageBox.Show(String.Format("Selected browser node : {0}", node.BrowserNodeDefinition.Label));
For an event, please try using the BrowserPanesEvents.
You can get hold of it using the Document.BrowserPanes.BrowserPanesEvents.OnBrowserNodeActivate.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Hi Balaji,
thanks for your support. I got the example running and capture the selection with a timer although I would prefer an event.
Unfortunately I don't get the BrowserPaneEvents with the EventWatcher. Whatever I click it seems that the OnBrowserNodeActivate event is not fired.
Andreas
ekinsb
You don't need to go through the browser but instead can use the Document.SelectSet property.  This returns a SelectSet object which will contain whatever is currently selected in the document.  There is also an OnChangeSelectSet event that is fired whenever the contents of the selection changes.
Brian Ekins
Mod the Machine blog
Hi Brian,
thanks a lot for your assistance. I checked the DocumentEvents.OnChangeSelectSet-Event and this is obviously exactly what I was looking for. Really crazy that I dindn't see the wood for the trees.
Andreas
