Get Point in UserCoordinateSystem
I have a Problem and need help.
I want to get the coordinates of an workpoint in a UserCoordinateSystem (UCS).
I thought i can get it with the function „TransformBy“
point.TransformBy(UCS.Transformation)
But for the example in the screenshot i get the result: X: 0, Y: 2, Z: 0 … but it should be X: 0, Y: 0, Z: 0
Here a example-Code:
Public Sub test()
    Dim p As PartDocument
    Dim oTG As TransientGeometry
    Dim u As UserCoordinateSystem
    Dim wp As WorkPoint
    Dim point As point
    Dim v As Vector
    Set p = ThisDocument
    Set oTG = ThisApplication.TransientGeometry
    Set u = p.ComponentDefinition.UserCoordinateSystems.Item(1)
    For Each wp In p.ComponentDefinition.WorkPoints
        Debug.Print wp.Name
        If (InStr(1, wp.Name, "Point", vbTextCompare)) Then
            Debug.Print "Orig x: " & wp.point.X & ", y: " & wp.point.Y & ", z: " & wp.point.Z
            Set point = wp.point.Copy()
            Call point.TransformBy(u.Transformation)
            Debug.Print "Transform x: " & point.X & ", y: " & point.Y & ", z: " & point.Z
        End If
    Next
End Sub
johnster100
Hi Guys,
Did you ever manage to get this to work?????????
If so the code would be useful to me. I'm trying to output work point coordinates to excel using ilogic.
thanks,
John
i solved my problem and because some people asked if i already have a solution i want to share it with you
the transformation-matrix has to be inverted before transformation
Private Function TransformByUserCoordinate(ByVal Point As ADSKInventor.Point) As ADSKInventor.Point
  Dim UCS As ADSKInventor.UserCoordinateSystem = GetUserCoordinateSystem()
  TransformByUserCoordinate = Nothing
  If (UCS IsNot Nothing) Then
    TransformByUserCoordinate = Point.Copy()
    Dim TransformMatrix As ADSKInventor.Matrix = UCS.Transformation
    TransformMatrix.Invert()
    TransformByUserCoordinate.TransformBy(TransformMatrix)
  End If
End Function
